980ti with Hybrid cooler random false temperature read and ran speed fluctuation to 100%
velociraptorbaby
2016/11/24 07:06:49 (permalink)
Hi,
I've got a Zotac 980ti with an EVGA Hybrid cooler added to it. I know. Try getting a Hybrid 980ti on release month in the UK..
The set up works fine 99.9% of the time and decent temps etc and I've got a fairly tasty overclock going on.
The problem, as the title suggests, is that randomly, when I am AFK and the system is idle, lock screen or not logged in/sitting on the desktop the fans randomly speed up and down in 5/10 second intervals and when I look inside of Precision X and Corsair Link both read 92c.
If I restart the system the issue persists, but a shut down and boot from cold seems to banish it, returning nice idle temps of 29c.
This has happened maybe 5 times in the last several months, over various builds of Windows 10 and multiple GPU drivers from Nvidia..
SO, potential causes? I think it's a software bug. I don't want to think that it's a faulty hardware issue as it's so intermittent and is easily resolved by cold booting. I am flapping however, warranty concerns and what not.
Some other info that might be useful.
5820k @ 4.4 on water
16gb 2133 DDR4
980ti Ref Zotac with Hybrid EVGA cooler
MSI x99 Krait Edition
Corsair Hx850 Psu.
Background/launch apps; McAfee, Corsair Link, Precision X, Steam, Origin, Curse, Skype, Adobe CC, Autodesk Application Manager and Google Drive.
None of which will likely be the cause If the system hasn't been logged in, I assume.
My current machine.
5820k @ 4.4Ghz
Corsair H100i GTX Cooler
MSI x99 Krait Edition Motherboard
16gb of Corsair LPX DDR4 @ 2133Mhz
Zotac 980ti with EVGA Hybrid Cooler @1415Mhz
512Gb Samsung 950 Pro NVME M.2 SSD
480Gb Crucial M500 Sata SSD
Corsair HX850 PSU
NZXT s340 Razer Edition Case
27" Asus PG279Q 165Hz IPS Gsync Monitor
Razer Black Widow 2013 Mechanical Keyboard
Razer Death Adder 2013
MacBook Pro Late 2013 with "Retina" 2560x1600 512Gb Samsung 950 Pro NVME M.2 SSD
2 Replies Related Threads
    arestavo
    • Ribbons : 8
    Re: 980ti with Hybrid cooler random false temperature read and ran speed fluctuation to 10 2016/11/24 08:07:06 (permalink)
    Since the temperature sensor is on the GPU and not the Hybrid cooler, it very well might be the GPU flaking out.
    I ran my 980 Ti Classified (stepped up to 1080 ACX) as well as my 980 Ti G1 Gaming card with a two different AIO coolers (H55 and X41) and never had that issue.
    Depending on what driver you are using, it might also be a driver issue. The last truly bug free driver (for me) that Nvidia released was the 373.06 driver. You might want to try using DDU in safe mode and then installing them to see. You can find them in the Beta and Older driver list - http://www.nvidia.com/Dow.oad/Find.aspx?lang=en-us
    EVGA affiliate code: 9ZWDWFNW6A
    (Don't forget to upload your invoice or no credit is given!)
    FOLD ON
    • Ribbons : 122
    Re: 980ti with Hybrid cooler random false temperature read and ran speed fluctuation to 10 2016/11/24 12:14:13 (permalink)
    Was the hybrid pump still running when this was occurring?
