980ti Hybrid Radiator orientation question - will I suck air?
Ozy311
2015/08/23 05:43:54 (permalink)
I am going to reverse the fans to pull not push for dust reasons, but my main question is orientation of the hoses.  Someone told me that if I orientated it like this:
that I could get air into the system because the hoses are at the top.   Can someone confirm this for me?  I could likely turn them 90 degrees to prevent that if it was true.
Thank you!
-Ozy
4 Replies Related Threads
    MunneY
    Re: 980ti Hybrid Radiator orientation question - will I suck air? 2015/08/23 06:34:37 (permalink)
    If you set the to intake air then you'll need to have the Rear fan exhausting tof create positive pressure. The placement of the tubes doesn't really matter.
    ErinW
    Re: 980ti Hybrid Radiator orientation question - will I suck air? 2015/08/23 08:04:55 (permalink)
    Mounting them with the hoses down is the best, and have the pump lower than the radiator.
    Mekhed
    Re: 980ti Hybrid Radiator orientation question - will I suck air? 2015/08/23 11:15:27 (permalink)
    AIO water coolers have air in the system by design to allow for expansion. You want the air trapped in the radiator away from the hose inlet and outlet
     "Kaos"   ASUS RAMPAGE V EXTREME | Intel Core i7-5930K | Corsair H110i GTX | 2x 1080TI Hybrid & 1080 Hybrid | HyperX 32GB 3000 | Supernova 1200 | Corsair 780T
    "BigDawg" Asus Maximus VI Formula | i7-4790k | Corsair H100i | 2x RTX 2080 Ti FTW3 Ultra | Mushkin Redline 16GB 2400 | Supernova 1300 | Antec 1200
    Ozy311
    Re: 980ti Hybrid Radiator orientation question - will I suck air? 2015/08/23 14:50:42 (permalink)
    Hmm, I just discovered I can't flip them left or right because they are too wide and hit each other.   I can't easily turn them upside down because they but up against the back of the video cards.  I may be forced to keep them hose up.   The manual does not state any required rotation angle.   Are you sure that internally the bibs don't extend further down into the radiator itself?  It would be bad design to have this limitation and then not state it in the user manual.
