Hopper64
Just installed a new Acer XB270HU monitor with my 980s SLI today. Everything works fine but the top card idles at 1012MHz instead of 135 that I am used to. Corresponding temp at idle is 35C. Is this due to the new native resolution of this monitor at 2560x1440 or something like that? Old monitor was a 1920x resolution. What's the problem here? Thanks.
Asus Maximus Z690E i9 12900KS GSkill F5-6000U3636E16GX2-TZ5RK Samsung 980 Pro Corsair AX1600i Asus Strix 3090 OC EKWB Quantum Kinetic TBE 300 and VTX 160 Creative SB X4 Asus ROG XG349C
EVGATech_ChrisB
EVGA Tech Support
Re: 980s SC top card stuck at 1012MHz
2015/04/01 16:55:59
Hi Hopper64, I can confirm that this is normal since you are now running at 144 Hz refresh.
Hopper64
2015/04/01 17:13:11
I was running at 144 with the old monitor too, but it was at 1920x... Is it the higher resolution and refresh rate that causes this? Thanks. BTW-The second card is at 135MHz as usual.
Hopper64
2015/04/01 17:15:12
Oh, just changed the RR to 120 and the top card decreased to 135MHz immediately. Thanks.
2015/04/01 17:16:11
Change desktop refresh rate to 120Hz & set power management mode under global settings inside the nvidia control panel to adaptive. Reboot PC. Should be good to go now.
Hopper64
2015/04/01 17:30:12
Yep. Power management mode was already on adaptive. Just changed the RR to 120 and we're OK now. Thanks for the help as always.
EVGA_JacobF
- Ribbons : 26
2015/04/01 17:43:22
Yes higher resolution + refresh rate needs a higher pixel clock and thus a higher idle clockspeed.
Hopper64
2015/04/01 17:46:43
EVGA_JacobF Yes higher resolution + refresh rate needs a higher pixel clock and thus a higher idle clockspeed.
Thanks. Learn a little every time something like this comes up. Appreciate the insight.
Hopper64
2015/04/02 17:20:53
Noticed a new problem with this. Most common game I play is IL2 Battle of Stalingrad and noticed after playing the game that it must make the RR change in the Nvidia CP back to 144. I have seen this happen several times now. I have set the RR in the game to 120 and applied that change in the game. But when I check the Nvidia CP, it is back to 144 on the RR. ?? Is this a game bug?? Thanks.
2015/04/02 17:27:54
Hopper64 Noticed a new problem with this. Most common game I play is IL2 Battle of Stalingrad and noticed after playing the game that it must make the RR change in the Nvidia CP back to 144. I have seen this happen several times now. I have set the RR in the game to 120 and applied that change in the game. But when I check the Nvidia CP, it is back to 144 on the RR. ?? Is this a game bug?? Thanks.
Sounds like a bug. Does this happen with any of your other games?
Hopper64
2015/04/02 17:38:08
Honestly don't have anything else on this machine to test. ??
2015/04/02 17:40:22
Ok. You should try a clean install of the latest nvidia driver to see if it helps.
Hopper64
2015/04/02 17:42:16
Yea. I could try that. Works fine except when I play the game. ?? Thanks.
Hopper64
2015/04/03 06:12:16
Stupid mistake. Reinstalled and noticed in my program tab settings in the Nvidia CP that I had "Highest Available" for the refresh rate instead of "Application Controlled". Dumb Dumb me. Thanks for the help.
- Ribbons : 84
2015/04/03 06:22:28
Hopper64 Stupid mistake. Reinstalled and noticed in my program tab settings in the Nvidia CP that I had "Highest Available" for the refresh rate instead of "Application Controlled". Dumb Dumb me. Thanks for the help.
No problem. Good troubleshooting on your part for finding this.
Hopper64
2015/04/03 08:28:49
Thanks. Guess reinstalling the same driver won't harm anything.
