Re: 980 ti high idle clocks and temp
2016/06/27 11:36:49
The best thing to use is the Multi Display Power Saver in
NVIDIA Inspector. It forces your cards to downclock, lowers the voltage, and returns temps to normal levels. The only thing is you have to add all of your games and benchmarks to a list so it will not run during when those specific applications are running. Not really a big deal just something you should know.
It will start with Windows if you would like and works perfectly from my experience. Give it a try.
ASUS RTX 4090 TUF OC • Intel Core i7 12700K • MSI Z690 Edge WiFi • 32GB G.Skill Trident Z • EVGA 1600T2 PSU
3x 2TB Samsung 980 Pros in RAID 0 • 250GB Samsung 980 Pro • 2x WD 2TB Blacks in RAID 0 • Lian-Li PC-D600WB
EK Quantum Velocity • EK Quantum Vector² • EK Quantum Kinetic TBE 200 D5 • 2x Alphacool 420mm Rads
LG CX 48" • 2x Wasabi Mango UHD430s 43" • HP LP3065 30" • Ducky Shine 7 Blackout • Logitech MX Master
Sennheiser HD660S w/ XLR • Creative SB X-Fi Titanium HD • Drop + THX AAA 789 • DarkVoice 336SE OTL
