Hi there,
I have a 980 ti hybrid kit coming in soon for my 980 Ti. I found out that you have to leave the fan for the VRM and memory cooling in, I got the hybrid kit specifically to get rid of the horrid noise those fans make when gaming or under moderate load (50 Celsius) I am wondering if I can leave the VRM cooling fan at around 25-30%, this is the speed where it makes no annoying noise.
I also have some Noctua 4-pin fans that I can't fit on the header that comes with the kit, does the header that comes with the kit do anything special? I was thinking of just leaving the fan plugged in on my motherboard and having the motherboard ramp the fan speed up whenever it deems necessary.
EDIT: I have two kits coming in soon, I am running an SLI setup for if that makes any difference.
