Answered980 Ti Hybrid without 8 pin power connector?
kyle2458
2015/12/01 21:37:54 (permalink)
Hey guys, I'm close to pulling the trigger on a 980 Ti Hybrid. My power supply is 1000 watts but it only has one 8 pin connector which is currently being used by the CPU. What are my options for powering the card.
Also I have a coolermaster Haf X case. It has one 140 mm fan in the back which is currently being used by my CPU radiator. The other fans are 200 - 230 mm. It's a very popular case so I was wondering where people normally mount the radiator for the 980 Ti?
Thanks
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/01 21:52:26 (permalink) ☄ Helpfulby kyle2458 2015/12/02 08:29:22
You will need to use some 6-pin to 8-pin adapters or molex to 8-pin adapters for the cards power.
Kramps
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/01 21:57:40 (permalink)
Pretty sure your 1000w power supply has to have at least two 6+2 PCI-e connectors.... Unless it's modular and they are.... lost :)
kyle2458
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/01 22:31:01 (permalink)
Kramps my power supply is an Ultra x3, about 8 years old now. I can't post a link with a picture because my account is new, but I've attached one:
Thanks for the info about the adapter. I'm assuming that's what the 2 6 pin to 8 pin adapter that they give you with the card is for?
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/01 22:44:55 (permalink)
kyle2458
No problem. Yes.
Kramps
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/02 06:22:06 (permalink) ☄ Helpfulby kyle2458 2015/12/02 08:28:03
The specs page for the Ultra X3 1000w have listed (2) 8-pin PCI-E
http://mail.ultraproducts.com/product_details.php?cPath=97&pPath=632&productID=634
Qty
Cable Description
Length(inches)
1
24 Pin Motherboard Connector
19.5
1
4 Pin +12V Motherboard Connector
19.5
1
8 Pin EPS Connector
19.5
4
6 Pin PCI-Express Connectors
19.5
2
8 Pin PCI-Express Connectors
19.5
2
5 Pin SATA Power Cable (3 Devices)
25.5
2
5 Pin SATA Power Cable (2 Devices)
21.5
1
4 Pin Power Cable (2 Devices)
23.5
2
4 Pin Power Cable (2 Devices + 2 Floppy)
29.5
1
4 Pin Power Cable (3 Devices)
23.5
1
4 Pin Power Cable (1 Device)
7.5
1
3 Pin Fan Connector (3 Devices)
25.5
post edited by Kramps - 2015/12/02 06:30:09
Kramps
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/02 06:29:36 (permalink) ☼ Best Answerby kyle2458 2015/12/02 08:29:13
Looks like this is one of the first implementations of the 8pin PCI-e power.  Dig through your cables and find the connector with 8+2 (for the gpu) on one end and 6 on the other end, which plugs into the PSU.
From the 2007 JonnyGuru review:
http://www.jonnyguru.com/...;op=Story2&reid=41
Page two pictures the cable.
One nice thing about the X3 is that it has native support of the upcoming 8 pin PCI-e standard. No adaptors needed for this baby although as of now the 8 pin cables feed off a 6 pin plug on the unit. A little birdie tells me that Ultra has a redesign in the works which will put the 8 pins on native 8 pin plugs on the PSU body and two of the 6 pin cables will adapt down from them instead of it being the inverse as it is now. Does it make much of a difference? Not really owing to the fact that as of now the extra two pins on the 8 pin plugs are grounds. There's all this hoopla over the 8 pin handling more wattage when in fact there are still three 12V power leads and five grounds rather than three +12V and three grounds. The new standard will eventually implement a 12V sense where the new grounds reside. How this equals more power capacity I really don't understand but I suppose that better minds than mine have decided it will work so that's all that matters.
kyle2458
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/02 08:25:43 (permalink)
Kramps thanks for the info. I didn't consider looking through my extra cables. Also didn't know there were adapter cables like that (6 on on end 8 on the other). Thanks again.
Kramps
Re: 980 Ti Hybrid without 8 pin power connector? 2015/12/02 10:37:38 (permalink)
kyle2458
Glad to help.  I had also never heard of it.  Apparently they built that PSU during a time of change in the PCI-E power requirements.  That being said... 8 years is getting up there in a PSU lifespan.  Not saying its death is imminent,  but you should definitely keep an eye on things.  If you start seeing odd things going on with your computer, the PSU could be the culprit.
