790i FTW and qx6850 - need overclock help
Page: < 12345.. > >> Showing page 4 of 7
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/25 09:50:35 (permalink)
lol on the balcony? lol You Russians  lol  Beware of condensation, Alex...it's not a good idea to run it outside.....especially when you tuen it off or bring it in, then the water will appear...be careful!!!
Ok...so, the workers stopped. You need to post the error that it came up with and we can try to work tru why it stopped. Once a worker, or CPU stops, it's a fail...don't continue...Stop all workers, go back to your bios, make some adjustments and try again...but we will need the error  so try to re-create it? Run a blend test, let it fail and post the error here!
Without being certain, it's prob. your RAM that will need the tweaks. If you want to try something before posting back to me....use the timings 8-9-8-25 or 26.... or 9-9-9-27 or 28. Try and set the timings nice and loose for now and see if we can get a passed test or 12!
post edited by Peter Northbridge - 2011/02/25 09:54:24
Classified3E770-i7960 @ 4.2 -ApogeeXT-MCR220-MCB120 Rev.2-MCRES Micro Rev.2-MCP655B
XPS720 Case-custom BTX to ATX mod-Mountain mods black anodized EATX tray-GTX580 850/2100-12GBXMS3 @ 2005
RevodriveX2 240GB-WD2TB-WD1TBx2-OCZ ZX 1000W- Logitech K800/G13/G27-Steel series XAI -LG 2753V-
#91
gottex
Re:790i FTW and qx6850 - need overclock help 2011/02/25 10:10:16 (permalink)
Yeah )) balcony, but its like a room, only not heated during winter, so there is no snow or mud or anything ;) Anyway, the PC is still running Prime, ofcourse I won't turn it off, cause water may freeze and after BILL 4 NEW PC )))
8-9-8-25
[Fri Feb 25 21:16:11 2011]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
8-9-8-26
[Fri Feb 25 21:24:06 2011]
9-9-9-27 or 28
gives me BSOD long before Win LOGO
I also did the following
**Memory Timing Setting**
Memory Timing Setting - [Expert]
x tCL (CAS Latency) – 8
x tRCD - 8
x tRP – 8
x tRAS - 24
x Command Per Clock – 2T
** Advanced Memory Settings **
[Auto].
x tRRD [Auto(7)]
x tRC [Auto(46)]
x tWR [Auto(12)]
x tWTR [Auto(19)]
x tFAW [Auto(35)]
X RFC [Auto(110)]
x tREF [Auto] -----} changed manually into 7.8
**System Voltages**
EVGA VDroop Control [Without VDroop]
CPU Core – 1.46250
CPU FSB – 1.425V
Memory – 1.800V ------} 1.9V gives STOPPED WORKER in any test
nForce SPP – 1.42V
nForce MCP – 1.550V
CPU PLL -  1.5V
after I changed x tREF I managed pass 12 test on Core 0 and 1 (I stopped them manually), but Core 3 passed 2 tests, Core 4 passed 4 tests only
post edited by gottex - 2011/02/25 11:03:33
CPU: Intel QX6850@3.6Ghz (1.45625v) Motherboard: EVGA 790i SLI FTW (bios SZ17)
Video: Tri-SLI MSI N580GTX-M2D15D5  772MHz/4008MHz
Memory: Kingston HyperX KHX1800C9D3K2/4G, DDR3 4Gb PC3-14400 1800MHz, 9-9-9-27 (2T) 1.8v
HDD1: WD VelociRaptor 150Gb SATA-II 10000rpm HDD2: WD VelociRaptor 300Gb SATA-II 10000rpm
HDD3: WD 1002FBYS 1Tb SATA-II 7200rpm PSU: Enermax Galaxy EVO 1250W Revolution 85+
Case: Cooler Master Stacker 832 OS: Windows 7 64-bit
Water cooling: XSPC RX480; Koolance PMP-450; XSPC Acrylic Dual 5.25" Bay Reservoir for Laing D5; Koolance CPU-370; Bitspower BP-WBN79NS-BK; Bitspower BP-WBN79AP1-BK & BP-WBN79AP2-BK
#92
gottex
Re:790i FTW and qx6850 - need overclock help 2011/02/25 12:04:25 (permalink)
so I got a little progress in BLEND test
x tRCD - 8
x tRP – 8
x tRAS - 24
[Auto].
x tRRD [Auto(7)]
x tRC [Auto(46)]
x tWR [Auto(12)]
x tWTR [Auto(19)]
x tFAW [Auto(35)]
X RFC [Auto(110)]
x tREF 7.8
**System Voltages**
CPU Core – 1.46875
CPU FSB – 1.425V
Memory – 1.800V
nForce SPP – 1.42V
nForce MCP – 1.550V
CPU PLL -  1.5V
GTLVREF Lane 0 [+0mv]
GTLVREF Lane 1 [+0mv]
GTLVREF Lane 2 [+50mv]
GTLVREF Lane 3 [+50mv]
worker 1 passed 29 tests in 38 minutes - 0 errors, 0 warnings (manual stop)
worker 2 passed 25 tests in 34 minutes - 1 error, 0 warnings (FATAL ERROR: Rounding was 0.5, expected less than 0.4)
worker 3 passed 23 tests in 31 minutes - 1 error, 0 warnings (FATAL ERROR: Rounding was 0.5, expected less than 0.4)
worker 4 passed 30 tests in 38 minutes - 0 errors, 0 warnings (manual stop)
Now I'll try CPU Core – 1.47500
worker 1 passed 7 tests in 12 minutes - 0 errors, 0 warnings (manual stop)
worker 2 passed 8 tests in 12 minutes - 1 error, 0 warnings (FATAL ERROR: Rounding was 0.5, expected less than 0.4)
worker 3 passed 8 tests in 12 minutes - 0 errors, 0 warnings (manual stop)
worker 4 passed 6 tests in 10 minutes - 1 error, 0 warnings (FATAL ERROR: Rounding was 0.5, expected less than 0.4)
post edited by gottex - 2011/02/25 13:38:15
#93
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/25 15:04:58 (permalink)
ok.....You're getting close! If you're passing a few tests on core 1 and core 2 fails, then yeah...we're very close.   Leave your RAM, then...it doesnt like more volts or looser timings...some RAM just has to be what it says on the stick and nothing else. Use the normal Timings like you have them. Try the CPU core @ 1.48, see if you get stable....Boost the GTLVref to the cores that are failing, as well.
GTLVREF Lane 0 [+0mv]   Leave this
GTLVREF Lane 1 [+0mv]  Change to +50
GTLVREF Lane 2 [+50mv]  Leave this
GTLVREF Lane 3 [+50mv] Change to +100
Let me know if that works out.  Keep upping the volts untill you  get all 4 cores to pass tests, just do not go over 1.5vcore.  If you find worker 2 stops first, exit prime 95, goto the bios, bump the volts to core 2, then go back to Prime 95 and test. Remember to only change one setting at a time in the bios once you get close like we are now... so that we will know if changing a the voltages is the issue...Sounds like you're making some progress tho!
#94
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2011/02/25 15:09:15 (permalink)
I don't have time to read this whole thread, so I will ask....what frequency are you running your CPU at that requires 1.48v?
#95
gottex
Re:790i FTW and qx6850 - need overclock help 2011/02/25 15:19:37 (permalink)
Peter Northbridge
Thanx man, I'll try that tomorrow, now I really wanna go to sleep )))  (its 2:18 AM in Moscow ;) )
#96
gottex
Re:790i FTW and qx6850 - need overclock help 2011/02/25 15:21:34 (permalink)
VistaHead
CPU Freq, MHz – 3600
FSB Reference Clock, MHz – 1800
CPU Multiplier - [8X]
#97
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2011/02/25 15:49:05 (permalink)
IMO, there is no way running a CPU with a stock frequency of 3.0Ghz and a FSB of 1333Mhz should require 1.48v to run at 3.6Ghz.  IMO, you are overvolting that chip.
#98
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/25 18:01:29 (permalink)
His FSB is 1800, read the whole thread. 65nm chip. Not 1333. Not 3.0ghz.  :P
If you can't get some stability here Alex, Try using an FSB of 1750. Leave all your timings where they are and the voltages, etc . Manually set the FSB to that, you're linked and sync'd so there's something else to try. Hope you got it working by the time I check tomorrow!
You're getting close!!
#99
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/25 18:05:00 (permalink)
If there's better advice to be had, go ahead.... See if you can help rather than take this thread backwards. again
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2011/02/25 18:11:02 (permalink)
Peter Northbridge
I know his FSB is 1800Mhz, and I know it is a 65nm CPU.  I know that 65nm chips require a little more voltage.  I suggest that you look at the specs on the CPU.  I read the entire thread.  I say 1.48v is high for 3.6Ghz.  The OP can do whatever he wants.
3.0Ghz
FSB - 1333Mhz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115026
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2011/02/25 18:26:30 (permalink)
Peter Northbridge
Yes, I do have better advice.....the problem is this:
Memory: TW3X4G1800C8DF Corsair Dominator DDR3 2x2Gb PC3-14400@1800MHz 8-8-8-24(2T) 1.80V - factory settings
Some of the 790i series boards can run the Dominator RAM well, quite a few don't.  Freezing in a lot of cases is either GPU or memory related.  He would not hardly be the first person that Dominator RAM just didn't play well with his chipset....even after adjusting the GTLVREF lanes.  Overvolting the hell out of the board and the components is not going to fix the problem. But....I will stay out of it.....
post edited by VistaHead - 2011/02/25 18:29:30
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/26 07:40:58 (permalink)
What I was suggesting was some advice, some help...Rather than saying IMO, I think this, etc.  Alex still has problems with his OC....Actually giving him advice rather than opinions will solve his issue. Anyone can just as easily go into another thread, tell someone that they're doing it wrong...without actually telling them how to do it right...but that does nothing...takes the thread no where. .. Let's actually help the user instead of just throwing 7549 opinions out there.
1.728vcore almost 5ghz
http://hwbot.org/community/submission/1026128_systemviper_cpu_z_core_2_qx6850_3.00ghz_4895.15_mhz
1.488vcore...4ghz, similar FSB
http://hwbot.org/community/submission/929947_silverlight_cpu_z_core_2_qx6850_3.00ghz_4049.82_mhz
So....What will fix the problem? I'm sure Alex would love to hear about it. Please help, or don't. It's simple!  We're here to help users.
post edited by Peter Northbridge - 2011/02/26 07:43:45
gottex
Re:790i FTW and qx6850 - need overclock help 2011/02/26 07:47:53 (permalink)
Peter Northbridge
THANX, I really appreciate your help !!!
Peter Northbridge
So far, I got to this:
CPU Core – 1.48125
GTLVREF Lane 1 [+50mv]
GTLVREF Lane 2 [+50mv] - stopped on test 1
GTLVREF Lane 3 [+100mv]
GTLVREF Lane 2 [+65mv]
GTLVREF Lane 3 [+100mv] - stopped on test 1
GTLVREF Lane 2 [+65mv] - stopped on test 8
GTLVREF Lane 3 [+75mv]
GTLVREF Lane 1 [+50mv] - stopped on test 1
GTLVREF Lane 2 [+60mv]
GTLVREF Lane 1 [+60mv] - stopped on test 1
GTLVREF Lane 0 [+0mv] - stopped on test 1
GTLVREF Lane 1 [+65mv]
post edited by gottex - 2011/02/26 08:26:51
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2011/02/26 07:54:24 (permalink)
Peter Northbridge
And what are you misreading in my post?  My advice is to replace the RAM.
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/26 08:23:50 (permalink)
Ok, Alex...Try putting the FSB to 1750. You should be able to do this with a vcore of 1.48 or less, like I said earlier. Leave all your timings and stuff where they are, just back off the FSB by 50 mhz and see what you get. If you fail tests, back off the FSB more, go down to 1700..then we can back off your voltages as well.
Vista Head may be able to help you as well. He says replace the RAM. Your errors in prime95 are more than likely memory related however you've done all the mem tests already so there's a chance you just need to do some more tuning.
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2011/02/26 08:32:16 (permalink)
Peter & Alex, if I sound like a jerk, that is not my intent, and I apologize.  It's just that I have seen too many cases where a member tweaks, and tweaks, and tweaks, and get to a point where that may appear to be stable, then a little while later, find out that they are not.  Alex, if you find that you cannot get stable after a little while longer, and a few more tweaks, if it were me, I would consider replacing the RAM.  The 790i chipset is finicky, especially when it comes to RAM.  Like I previously stated, some members can run the Dominator memory well, but some members never successfully run it, no matter what they adjust.  Play with it some more, but I feel that in your particular case, it is the RAM....but I could be wrong...which is the problem.
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/26 08:35:12 (permalink)
The only reason you'd be a jerk was if your computer was better than mine. lol
gottex
Re:790i FTW and qx6850 - need overclock help 2011/02/26 09:15:43 (permalink)
VistaHead
Thats ok, I take in consideration any help guys, and I wanna thank u all for being helpful each. I'm really a dumm@$$ in OC so I'm gonna listen to everything you guys tell me and see if its working or not. No jerks here, just friends and colleagues
Well Peter, I try my last attempt with 1800 after I go a bit down as you told me to. BTW, while you made some posts here, I was running Prime95 with this (thought it was a bingo, but I was mistaken ):
GTLVREF Lane 0 [+75mv]
GTLVREF Lane 1 [+65mv] - stopped on test 23, ran for 32 minutes, not bad I guess
gottex
Re:790i FTW and qx6850 - need overclock help 2011/02/26 11:33:27 (permalink)
No luck again
**Frequency Settings**
CPU Freq, MHz – 3500
FSB Reference Clock, MHz – 1750
CPU Core – 1.48125
CPU FSB – 1.425V
Memory – 1.800V
nForce SPP – 1.42V
nForce MCP – 1.550V
CPU PLL -  1.5V
GTLVREF Lane 0 [Auto]
GTLVREF Lane 1 [Auto]
GTLVREF Lane 2 [Auto]
GTLVREF Lane 3 [Auto]
Worker 2 stopped test 3
CPU Freq, MHz – 3400
FSB Reference Clock, MHz – 1700
Worker 4 stopped test 2
post edited by gottex - 2011/02/26 11:37:12
danno428cj
Re:790i FTW and qx6850 - need overclock help 2011/02/26 15:46:12 (permalink)
ur voltage is fine, dont go over 1.5, i had to run 1.5 just to get 3.5GHz on my q6700
Gigabyte  Z77 G1 Sniper3 LGA 1155
Intel Core i7-3770k @ 4.2
G.Skill Ripjaws X Series 8GB (2X4GB) PC3 14900 @ 1866
EVGA GTX 780 Classified ACX
Western Digital Caviar Black 1TB RAID 0
Silverstone Strider Gold 1000w
Coolermaster HAF-932 case.
Peter Northbridge
Re:790i FTW and qx6850 - need overclock help 2011/02/26 16:35:34 (permalink)
I don't know, Alex. There's a possibility that your RAM just isn't compatible with the board.  Your stock voltage is 1.8...you tried 1.9 with no success..Try 1.825, leave the FSB @ 1800...then try 1.85 and so on. It's a memory related issue you're having for sure by the sounds of all of this, so maybe like Vista head stated..your RAM is a bad mix for your board. You can prob sell your RAM, replace it with something that works.....I have 2gb of OCZ3N2000SR I can give to you, but you live in Russia....would cost me a lot to ship it there and I'm not driving from Canada ! lol
If you want to pay for the shipping, I'll send it to you for free if you really want.
I'm using ADATA AX3U2000GC2G9B-2G, a 4gb kit i found for $50 CDN new
Here's the list of RAM that's supported by EVGA officially
  • nForce 790i Series Motherboard (DDR3, Dual Channel)
    • DDR3-2000
      • Crucial BL2KIT12864BE2009
      • OCZ OCZ3N2000SR2GK PC3 16000 ( What I have )
    • DDR3-1800
      • AXH860UD20-18J (2GB 1866Mhz)
      • Corsair CM3X1024-1800C7DIN
      • Corsair TW3X2G1800C7DFNV
      • Crucial BL2KIT12864BE1808
      • G.SKILL F3-14400CL7D-2GBHZ
      • Kingston KHX14400D3K2/2G
      • Kingston KHX14400D3K2/2GN
      • OCZ3N1800SR2GK PC3 14400
      • OCZ3N1800SR4GK PC3 14400
      • STAREX STH100UD0814-2000A
    • DDR3-1600
      • Aeneon AXH760UD20-16H-K-2G
      • AXH860UD20-16H (2GB 1600Mhz)
      • AXH760UD10-16H (1GB 1600Mhz)
      • Corsair CM3X1G1600C8D4 (1GB 1600Mhz)
      • Corsair CM3X2G1600C8D4
      • Corsair TW3X2G1600C7DHXNV
      • G.SKILL F3-128007L9D-2GBNQ
      • G.SKILL F3-12800CL7D-4GBP1
      • Kingston KHX13000D3LLK2/2GN
      • Kingston KHX13000D3LLK2 /2GX
    • DDR3-1333
      • Elpida EBJ10UE8BAFA-DJ-E
      • G.SKILL F3-10600CL7D-2GBP1
      • Hynix HYMT112U64ZNF8-H9
      • Hynix HYMT125U64ZNF8-H9
      • Hynix HYMT164U64ZNF6-H9
      • Kingston KVR1333D3N8K2/1G
      • Micron MT8JTF12864-1G4D1
      • PQI MFACR322LA0101-08B8
      • Qimonda IMSH51U03A1F1C-13H
      • Qimonda IMSH1GU13A1F1C-13H
      • Samsung M378B2873CZ0-CH9
      • Samsung M378B5673CZ0-CH9
    • DDR3-1066
      • Elpida EBJ10UE8BAFA-AE-E
      • Elpida EBJ10UE8BAFA-AG-E
      • Elpida EBJ21UE8BAFA-AG-E
      • Hynix HYMT112U64ZNF8-G8
      • Hynix HYMT164U64ZNF6-G7
      • Hynix HYMT125U64ZNF8-G8
      • Kingston KVR1066D3N7/512
      • Kingston KVR1066D3N7/1G
      • Micron MT8JTF12864-1G1D1
      • Micron MT8JTF12864AY-1G1BYES
      • Micron MT4JTF646AY-1G1B1
      • Micron MT16JTF25664AY-1G1BYES
      • Micron MT16JTF25664AY-1G1D1
      • Nanya NT512C64B88A0NY-BE
      • Nanya NT1GC64B8HA0NY-BE
      • PQI MFABR403PA0101-07D3
      • PQI PQI38500-2048DB
      • Qimonda IMSH51U03A1F1C-10G
      • Qimonda IMSH51U03A1F1C-10F
      • Qimonda IMSH1GU13A1F1C-10F
      • Qimonda IMSH1GU13A1F1C-10G
      • Samsung M378B2873CZ0-CF8
      • Samsung M378B5673CZ0-CF8
    • DDR3-800
      • Elpida EBJ10UE8BAFA-8C-E
      • Elpida EBJ21UE8BAFA-8C-E
      • Hynix HYMT164U64ZNF6-S5 AA
      • Hynix HYMT125U64ZNF8-S6
      • Hynix HYMT112U64ZNF8-S6 AA
      • Qimonda IMSH1GU13A1C-08D
      • Qimonda IMSH51U03A1F-08D
      • Micron MT4JF6464AY-80BB1
      • Nanya NT512C64B88A0NY-AD
    • http://www.evga.com/support/motherboard/
    So, I don't know what else to say, Alex..Keep trying if you want. It's really not too big of a cost to sell your existing RAM, try some other stuff that you know should work, then try your overclock..you've done it a few times, you're probably quite fast at it by now lol...... your hardware is also still valuable seeing as it's not cheap kids stuff, you can always sell it because it all works, just not together. Toss of a coin if you ask me!
    post edited by Peter Northbridge - 2011/02/26 16:39:35
  • Classified3E770-i7960 @ 4.2 -ApogeeXT-MCR220-MCB120 Rev.2-MCRES Micro Rev.2-MCP655B
    Peter Northbridge
    Re:790i FTW and qx6850 - need overclock help 2011/02/26 16:46:23 (permalink)
    Update: would cost $98.56 from fedex in shipping!  OWCH.
    gottex
    Re:790i FTW and qx6850 - need overclock help 2011/02/27 13:09:01 (permalink)
    Well Peter, thank you for your kindness!!!
    Tomorrow I look on the market for OCZ OCZ3N2000SR2GK PC3 16000, if I find one, I'll let you know.
    One more thing, I've read somewhere long ago that high speed memory must be placed in black slots, but if I buy this mem, its only 2Gb, so I need 2x2 Gb (1Gb in each slot), will it work ok on 1800 ??? Cause right now as u know, I have 4Gb (2Gb in each black slot)
    P.S.
    I found two shops that sells this mem ($120). I'll call tomorrow and see if they have it in-stock
    post edited by gottex - 2011/02/27 13:12:54
    VistaHead
    • Ribbons : 131
    Re:790i FTW and qx6850 - need overclock help 2011/02/27 14:10:26 (permalink)
    If you are going to run 4GB (2 X 2GB), then I recommend using the black slots.  Of course if you are going to run 8GB (4 X 2GB), then all slots will be populated.  Just so you know the following applies to the memory slots on the 790i FTW series boards:
    Blue slots - rated up to 1800Mhz
    Black slots - rated up to 2000Mhz
    Although the blue slots are rated up to 1800Mhz, I have seen threads where members had problems running RAM in the blue slots above 1600Mhz, and once they moved the sticks to the black slots, the problems went away...on the other hand, some folks have no issues at all.  I always recommend the black slots if you are running 2 sticks of RAM...regardless of the frequency that you are using.  The black slots appear to offer better stability....but that is my opinion.
    gottex
    Re:790i FTW and qx6850 - need overclock help 2011/02/27 14:25:42 (permalink)
    Ofcourse I need 4 Gb, but which combination is better ?
    In the list above, all sets of required memory are 2Gb. If I need 4Gb, but only 2 sticks, which one will be compatible with my board or should I try my fortune and buy 2 sets of 2Gb (1gb in each slot) and pray?
    VistaHead
    • Ribbons : 131
    Re:790i FTW and qx6850 - need overclock help 2011/02/27 14:34:13 (permalink)
    You want at least two 2GB (each) sticks for a total of 4GB of RAM.  Four 1GB sticks places unnecessary additional stress on the memory controller because it has to run all 4 slots, when you can get the same amount of RAM on two sticks.
    post edited by VistaHead - 2011/02/27 14:36:33
    gottex
    Re:790i FTW and qx6850 - need overclock help 2011/02/27 14:37:20 (permalink)
    VistaHead
    Yes, but these are all 2Gb x 2 sticks. You think I might not get stable if I go for 4 Gb x 4 sticks ?
    • DDR3-2000
    • DDR3-1800
      • OCZ3N1800SR4GK PC3 14400 - 4Gb x 2 sticks , but I'm not sure we have it in Moscow  many of these listed mem are out of stock, because its old and not popular
    • DDR3-1600
    post edited by gottex - 2011/02/27 14:42:28
    VistaHead
    • Ribbons : 131
    Re:790i FTW and qx6850 - need overclock help 2011/02/27 14:46:04 (permalink)
    That approved list of RAM for the 790i series boards has not been updated in a long time because the socket 775 series boards have reached their end of life (EOL).  It is so outdated, that you probably can't find more than half of the RAM that is on that list.  To be honest with you, I don't recommend OCZ RAM for the 790i series chipset.  While some folks can run it well, others have major issues with it.  If you do a "search" function here in the 7 Series forum menu, you will find plenty of threads where OCZ RAM ended up being the culprit.  If it were me, I would look for DDR3 dual channel RAM with a recommended voltage of 1.7v or higher.  Low voltage RAM (1.65v or lower) also give some people fits on the 790i chipset.  There are plenty of threads with that issue also.  Higher voltage Patriot RAM runs very well on the 790i chipset, but it is also getting hard to find due to it being EOL also.
    gottex
    Re:790i FTW and qx6850 - need overclock help 2011/02/27 14:52:51 (permalink)
    VistaHead
    Just found this one on market (only for $100) DDR3 4Gb (2x2Gb) PC3-14400 1800MHz DIMM Kingston HyperX Genesis, KHX1800C9D3K2/4G.
    What do you think of this one ?
    Or which memory would you suggest that is still on the market ?
    post edited by gottex - 2011/02/27 15:07:21
