790i FTW and qx6850 - need overclock help
Page: < 12345.. > >> Showing page 2 of 7
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/25 12:04:17 (permalink)
jeffreyham
Yes, Sir....each stick individually for 8hrs....then, both together in the black slots.
Ok, right now I have this (I can boot and even play, but with freezes):
**Frequency Settings**
CPU Freq, MHz – 4050
FSB Reference Clock, MHz – 1800
CPU Multiplier - [9X]
PCIe x16_1 & 16_2, MHz - 100
PCIe x16_3, MHz - 100
SPP<->MCP Ref Clock, MHz - 200
**HT Multiplier**
nForce SPP --> nForce MCP - [5 x]
nForce SPP <-- nForce MCP - [5 x]
**FSB & Memory Config**
EPP 2.0 Memory [Disabled]
FSB – Memory Clock Mode - [Linked]
FSB – Memory Ratio - [Sync Mode]
FSB (QDR), MHz - [1800]
Actual FSB (QDR), MHz - 1800
x MEM (DDR), MHz - [Linked]
Actual MEM (DDR), MHz - 1800
P1 - [Enabled]
P2 - [Enabled]
**Memory Timing Setting**
Memory Timing Setting - [Expert]
x tCL (CAS Latency) – 8
x tRCD - 8
x tRP – 8
x tRAS - 24
x Command Per Clock – 2T
** Advanced Memory Settings **
[Auto].
x tRRD [Auto(7)]
x tRC [Auto(46)]
x tWR [Auto(12)]
x tWTR [Auto(19)]
x tFAW [Auto(35)]
X RFC [Auto(110)]
x tREF 7.8uS
**System Voltages**
EVGA VDroop Control [Without VDroop]
CPU Core – 1.5000
CPU FSB – 1.350V
Memory – 1.800V
nForce SPP – 1.37V
nForce MCP – 1.550V
CPU PLL [Auto] 1.5V
GTLVREF Lane 0 [Auto]  +75mv
GTLVREF Lane 1 [Auto]  +50mv
GTLVREF Lane 2 [Auto]  +00mv
GTLVREF Lane 3 [Auto]  +00mv
Should I leave it like that and test each stick with this settings ???
P.S.
Just got freeze after win logo ((((
P.P.S.
After I set manually I managed to boot
GTLVREF Lane 0   +75mv
GTLVREF Lane 1   +50mv
post edited by gottex - 2010/08/25 12:13:35
CPU: Intel QX6850@3.6Ghz (1.45625v) Motherboard: EVGA 790i SLI FTW (bios SZ17)
Video: Tri-SLI MSI N580GTX-M2D15D5  772MHz/4008MHz
Memory: Kingston HyperX KHX1800C9D3K2/4G, DDR3 4Gb PC3-14400 1800MHz, 9-9-9-27 (2T) 1.8v
HDD1: WD VelociRaptor 150Gb SATA-II 10000rpm HDD2: WD VelociRaptor 300Gb SATA-II 10000rpm
HDD3: WD 1002FBYS 1Tb SATA-II 7200rpm PSU: Enermax Galaxy EVO 1250W Revolution 85+
Case: Cooler Master Stacker 832 OS: Windows 7 64-bit
Water cooling: XSPC RX480; Koolance PMP-450; XSPC Acrylic Dual 5.25" Bay Reservoir for Laing D5; Koolance CPU-370; Bitspower BP-WBN79NS-BK; Bitspower BP-WBN79AP1-BK & BP-WBN79AP2-BK
#31
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/25 12:11:39 (permalink)
Yes....you want to test your RAM at their rated spex of 8-8-8-24-2T 1800MHz. If both sticks pass the test then, as VistaHead said, the freezing issue is probably being caused by one of the GFX cards.
PLEASE REMEMBER TO UPLOAD A COPY OF YOUR INVOICE
   = My Current Linked and Synced Settings
All detailed system components are listed on my Mods Rigs page
#32
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/25 12:16:19 (permalink)
Try running the system for awhile with each GFX card individually to see if issues happen with a particular one....or if it only freezes while running SLI.
EDIT: Also, run the GFX cards with no OC on them...stock settings.
post edited by jeffreyham - 2010/08/25 12:20:38
#33
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/25 12:35:09 (permalink)
I apologize, Alex...I am going to have to go offline pretty soon to run some errands but, I will be back on later...just wanted to let you know that I am not abandoning you.
#34
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/25 12:38:34 (permalink)
jeffreyham
I'll run memtest tomorrow (cause its 11:28 PM in Moscow :) ) before work and leave it for all day .
Right now each stick is in black slot. Concerning  video cards, donno if its true, but I think I saw a post about a year ago that 790 motherboards had problems with single or maybe SLI cards with 2Gb on board. The thing is that I have two Palit GTX285 2048Mb 648Mhz/2484Ghz ... hope its not the issue ...
OC ? I never OC video, cause I'm a noob and donno how to do it :( sorry, this frequencies was reached by factory already when I bought it
P.S.
I AM VERY APPRECIATE FOR YOUR HELP!!! I wish I could thank you somehow ...
It's ok, I understand, we all have things to do ;)
post edited by gottex - 2010/08/25 13:26:07
#35
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/25 12:42:56 (permalink)
OK, Man....I am not aware of the possible 2GB video card issue that you mentioned but, I will do some research on that when I get back on later and see what I can find out.
Have a good one,
Jeff
P.S.- You telling me that you appreciate my help is ALL the thankx that I need. Cya later.
post edited by jeffreyham - 2010/08/25 12:46:12
#36
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/25 19:42:35 (permalink)
I'm not having any luck finding info on possible 2GB GFX card issues on the 790i MoBo.
#37
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/26 07:22:14 (permalink)
Hey Jeffrey,
So what I managed to do today (just got back from work, 6:23 PM) is to test two sticks of ram in black slots - no errors for 8 hours, please see the pic below.
The settings were the same as in previous post when I tried to load with 4050 Mhz:
**HT Multiplier**
P1 - [Enabled]
P2 - [Enabled]
x tRCD - 8
x tRP – 8
x tRAS - 24
[Auto].
x tRRD [Auto(7)]
x tRC [Auto(46)]
x tWR [Auto(12)]
x tWTR [Auto(19)]
x tFAW [Auto(35)]
X RFC [Auto(110)]
x tREF 7.8uS
**System Voltages**
CPU Core – 1.5000
CPU FSB – 1.350V
Memory – 1.800V
nForce SPP – 1.37V
nForce MCP – 1.550V
CPU PLL [Auto] 1.5V
#38
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2010/08/26 09:20:38 (permalink)
So how is the PC performing?
#39
danno428cj
Re:790i FTW and qx6850 - need overclock help 2010/08/26 09:38:51 (permalink)
At this point it is probably the chip holding you back. Reading soem other forums, some people had to switch to water and pump 1.6v into the chip for 4+ GHz. but you never know, please keep trying Jham and Vistaheads suggestions.
Are you using any CPU stability programs? (Prime95,  Intel Burn Test)
P.S. in another post a person had freezing in games only. The SSP voltage needed a bump. try the highest green voltage on the SSP and see if that gives you any stability in games.
post edited by danno428cj - 2010/08/26 09:48:25
Gigabyte  Z77 G1 Sniper3 LGA 1155
Intel Core i7-3770k @ 4.2
G.Skill Ripjaws X Series 8GB (2X4GB) PC3 14900 @ 1866
EVGA GTX 780 Classified ACX
Western Digital Caviar Black 1TB RAID 0
Silverstone Strider Gold 1000w
Coolermaster HAF-932 case.
#40
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2010/08/26 09:45:19 (permalink)
danno428cj
+1  That was going to be my next suggestion to him if the cards run fine individually.  He may want to keep his RAM and FSB at 1800Mhz, and lower his CPU multiplier (and voltage) to get stable.
#41
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/26 09:58:37 (permalink)
VistaHead
I can boot, I can play e.g. Mafia 2 for 10-15 min with freezes, then BSOD ... even Prime95 gives BSOD when I start "Blend" test.
With the settings in the the Post #1, I pass easily Prime95 v.25.11 build 2 64bit - 11 hours, In-place large FFT's (maximum heat, power consumption, some RAM tested), Advanced -  "Round off checking" CHECKED, but not "Blend", if I start stress with "Blend", it gives error right after the start with 1-2 cores (always different cores) and then I stop the test :(
#42
VistaHead
  • Ribbons : 131
Re:790i FTW and qx6850 - need overclock help 2010/08/26 10:01:48 (permalink)
have you tried what is in post #7?
#43
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/26 10:01:51 (permalink)
danno428cj
I use LinX 0.6.4; OCCT 3.1.0; Prime95 v.26.1 build 1 64-bit
#44
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/26 10:06:11 (permalink)
VistaHead
Not with one card yet, still not enogh time because of work, but I will !!! I only changed driver 258.96-->259.32
#45
RockaFeller
Re:790i FTW and qx6850 - need overclock help 2010/08/26 15:13:52 (permalink)
i just have to say.. why would you overclock a extrem chip by uping the fsb. i just thought that if it was me.... wouldent you change the multiplyer. thats why you buy an extrem chip the multi is unlocked. just saying... what do you think.
#46
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/27 05:18:50 (permalink)
Alex,
Sorry I wasn't on yesterday...was helping my folks deal with a family emergency.
Need you to test those 1800MHz settings with just 1 GFX card at a time as described in post #33 as soon as you can. If it is not one of the cards causing the issue then, we'll know we need to work on the CPU.
#47
danno428cj
Re:790i FTW and qx6850 - need overclock help 2010/08/27 06:02:02 (permalink)
RockaFeller
yes and no, honestly a OC on the FSB will be more benificial than an OC on the CPU. The FSB sets the speed for the rest of the system. It is the speed at wich all of the other components "talk" to each other. Since the OP is sorta maxing out at 4.0GHz. (1800FSB/4=450,  450*9=4.05GHz) we now need to take it down a little but we would want to try and keep the 1800 FSB. The next multi down is 8 (1800/4=450, 450*8=3.6GHz)
This way all the components are still "talking" to each other at 450MHz.
Lets say you want to OC by the multi. Lets shoot for the same 3.6GHz.
Lets jack the multi to 12. (3600/12=300, 300*4=1200FSB) Now the whole system has been dumbed down to 300MHz with the same CPU speed of 3.6GHZ
#48
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/30 12:39:50 (permalink)
Hello guys!
I'm very sorry for being out for 4 days, I was on the business trip, ohhrrr I wish I do not need to work till I get my PC stable ;) . Anyway, today I managed to test EACH VIDEO CARD separately with the BIOS settings in post #1 (3.6Ghz, most stable for Prime95) and the result is the same - I got freezes and stuttering but a bit more seldom
#49
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/30 12:46:33 (permalink)
Do you have time to try each card individually with the 1800MHz settings??
#50
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/30 12:51:21 (permalink)
jeffreyham
If not today, then tomorrow, but I will try right now with one and the second one for tomorrow, but please keep in mind that I can't get stable 1800- 4.05, cause after some time it gives me BSOD ... but I'll check right now anyway !
#51
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:790i FTW and qx6850 - need overclock help 2010/08/30 13:06:40 (permalink)
Gotchya. I'm starting to think that this may all boil down to your Corsair RAM "not playing nice" with your board.
#52
danno428cj
Re:790i FTW and qx6850 - need overclock help 2010/08/30 13:07:49 (permalink)
try 1800 FSB and a CPU multiplyer of 8 and see if that gives you any stability.
#53
Starspy
Re:790i FTW and qx6850 - need overclock help 2010/08/30 13:23:51 (permalink)
 I find it  slightly peculiar that he can pass stress tests but when in game he's having stability issues. I think something else is at play here. Possibly the GPU or a driver issue?
Can you take a picture of the BSOD next time it happens?
post edited by Starspy - 2010/08/30 19:32:09
Case: NZXT S340
Mobo: MSI Z87 G45
Video: EVGA GTX 780ti SC
Proc: Intel i5 4670k @ 4ghz
Ram: 2x4GB G.skill TridentX 2400mhz
PSU: Antec 650w
Drive: 256GB Samsung 840 Pro
#54
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/30 13:25:43 (permalink)
Ok guys, I played a whole chapter 3 in Mafia 2 with stutters and freezes with settings in POST #38, but not BSOD's thankfully ;)
sorry, its 12:24 AM, gotta get up early, promice to come back tomorrow and try your advices!!! Thanx ! Cia
#55
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/31 06:21:08 (permalink)
Well, its me again, probably most of the people get bored of my problem, sorry guys ;)
Anyway, I've made some tests and they all were with freezes and BSOD's
First, I played Mafia 2, Chapter 5 with two cards, one for video - one for PhysX (cause it gives more boost then SLI) with the next settings :
**HT Multiplier**
P1 - [Enabled]
P2 - [Enabled]
x tRCD - 8
x tRP – 8
x tRAS - 24
[Auto].
x tRRD [Auto(7)]
x tRC [Auto(46)]
x tWR [Auto(12)]
x tWTR [Auto(19)]
x tFAW [Auto(35)]
X RFC [Auto(110)]
x tREF 7.8uS
**System Voltages**
CPU Core – 1.5000
CPU FSB – 1.350V
Memory – 1.800V
nForce SPP – 1.37V
nForce MCP – 1.550V
CPU PLL [Auto] 1.5V
And I got freezes and then BSOD maybe after 5-10 min playing
#56
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/31 06:27:08 (permalink)
I'm sorry for MULTI POSTING but its the only way to attach all needed pic's to each message
Second try was also Mafia 2, Chapter 5 with two cards, one for video - one for PhysX, but the setting were ... see the pic ... and I had only micro freezes sometimes, then 3-4 big ones (when u have to press Alt+tab and back) and NO BSOD's thankfully, I played for 20-30 min
#57
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/31 06:31:57 (permalink)
The third case is when everything on default, auto , etc.
No freezes, No BSOD's !!! Can play SLI or one for video - one for PhysX, NO PROBLEM at all
P.S.
Some how I just got couple freezes with the defaults ... whatta heck ...
P.P.S.
Set MEMORY voltage to AUTO and GTLVREF Lane 1 +20mv ... yet stable ... Mafia 2 chapter 7
P.P.P.S.
Played from 7 to 11 Chapter ... not a single freeze on defaults
post edited by gottex - 2010/08/31 11:39:33
#58
gottex
Re:790i FTW and qx6850 - need overclock help 2010/08/31 06:40:13 (permalink)
But the strangest thing is when everything is on default, auto , etc. the PC boots like this (see Pic 1) and then goes all the info (Pic 2) the settings on Pic 2 was taken a while ago so its just as an example, but when you OC the system the boot process starts like on the (Pic 3) , it freeze for 1-2 sec like that and only after all, other info appears (Pic 2) ... so what it may be ? another trouble ? the main reason of my freezes in games ? ohhh wish I could solve all that ...
post edited by gottex - 2010/08/31 06:50:41
#59
danno428cj
Re:790i FTW and qx6850 - need overclock help 2010/08/31 09:00:57 (permalink)
ok, on your auto settings, only run the system on one card only, no SLI and no PhysX card.  run it for a while. then try your other card on it's own and see what happens.
also, i had a heck of a time with my Q6700 with FSB from 1600 to 1825.
so try your settings from post #38 but the CPU multiplyer at 8 and set the FSB at 1900
unlink the ram and set the memory ratio to auto, leave the ram at 1800
run Intel Burn Test for 20 passes at maximum.
post edited by danno428cj - 2010/08/31 09:06:22
#60
