VistaHead
- Ribbons : 131
Re:790i FTW and qx6850 - need overclock help
2011/02/27 15:34:33
gottex
2011/02/27 15:57:05
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2011/02/27 16:48:06
I agree, Alex......those Kingston's should be better stix. I sure hope it helps resolve the issue.
PLEASE REMEMBER TO UPLOAD A COPY OF YOUR INVOICE = My Current Linked and Synced Settings All detailed system components are listed on my Mods Rigs page.
gottex
2011/02/28 00:20:59
Well I just ordered this Kingston, shipping for tomorrow. Hope they'll work.
post edited by gottex - 2011/03/03 11:51:29
VistaHead
- Ribbons : 131
2011/02/28 04:40:18
gottex
2011/02/28 07:14:46
VistaHead Let us know the results. Trust me, u'll be the 1st to know First what I want to do tomorrow when I get my ram is to run a memtest for 6-8 hours, if there wont be any errors, then I can OC I posted in some Russian OC forum about mem problem and one very popular overclocker who used to deal pretty closely with 790i boards assured me that he had many models of Kingston ram for OC and testing, and all of them worked perfectly with 790i FTW, hope he is right.
CPU: Intel QX6850@3.6Ghz (1.45625v) Motherboard: EVGA 790i SLI FTW (bios SZ17) Video: Tri-SLI MSI N580GTX-M2D15D5 772MHz/4008MHz Memory: Kingston HyperX KHX1800C9D3K2/4G, DDR3 4Gb PC3-14400 1800MHz, 9-9-9-27 (2T) 1.8v HDD1: WD VelociRaptor 150Gb SATA-II 10000rpm HDD2: WD VelociRaptor 300Gb SATA-II 10000rpm HDD3: WD 1002FBYS 1Tb SATA-II 7200rpm PSU: Enermax Galaxy EVO 1250W Revolution 85+ Case: Cooler Master Stacker 832 OS: Windows 7 64-bit Water cooling: XSPC RX480; Koolance PMP-450; XSPC Acrylic Dual 5.25" Bay Reservoir for Laing D5; Koolance CPU-370; Bitspower BP-WBN79NS-BK; Bitspower BP-WBN79AP1-BK & BP-WBN79AP2-BK
2011/02/28 08:21:35
Well, good to hear! Hopefully you can get your stuff going!
Classified3E770-i7960 @ 4.2 -ApogeeXT-MCR220- MCB120 Rev.2-MCRES Micro Rev.2-MCP655B XPS720 Case-custom BTX to ATX mod-Mountain mods black anodized EATX tray-GTX580 850/2100-12GBXMS3 @ 2005 RevodriveX2 240GB-WD2TB-WD1TBx2-OCZ ZX 1000W- Logitech K800/G13/G27-Steel series XAI -LG 2753V-
gottex
2011/03/01 03:54:29
Finally, Kingston have arrived ;) Tonight I'll run memtest for errors. What timings and volt should I input ? Same as before, 1.8v 8-8-8-24(2T) ??? P.S. DESCRIPTION: Kingston's KHX1800C9D3K2/4G is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1800MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1800MHz at a low latency timing of 9-9-9-27 at 1.7V to 1.9V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
post edited by gottex - 2011/03/01 04:15:58
VistaHead
- Ribbons : 131
2011/03/01 04:44:26
Test the memory at the manufacturer's recommended timings and voltage of 9-9-9-27 @ 1.8v (split the difference in the voltage).
gottex
2011/03/01 12:27:58
I install memory, start the PC, got this terrible sound and error on the board 1C (CMOS battery check), so I pulled out battery, waited for 30 min, installed back and now I can't even start PC ))) when I turn on, I see RED light on the board (CPU hot led) and its immediately turning off automatically. I've had it once, but then it was gone by itself ... clear does no effect I've tried my old ram, new one, one stick, two sticks, different slots ... same red light as soon as I see loading screen with memory testing
post edited by gottex - 2011/03/03 11:50:45
VistaHead
- Ribbons : 131
2011/03/01 12:32:28
Are you saying when you turn the PC on, the red CPU LED stays lit? Do the other three LED's come on?
gottex
2011/03/01 13:02:56
VistaHead Are you saying when you turn the PC on, the red CPU LED stays lit? Do the other three LED's come on? Its ok now, probably was something with water pump connector. So which I should use for testing mem? all 4Gb or one 8 hour test for single 2Gb stick? - Download - Pre-Compiled Bootable ISO (.gz)
- Download - Pre-Compiled Bootable ISO (.zip)
- Download - Pre-Compiled Bootable Binary (.gz)
- Download - Pre-Compiled Bootable Binary (.zip)
- Download - Auto-installer for USB Key (Win 9x/2k/xp/7) *NEW!*
- Download - Pre-Compiled EXE file for USB Key (Pure DOS) *OBSOLETE*
- Download - Pre-Compiled package for Floppy (DOS - Win)
post edited by gottex - 2011/03/03 11:50:20
VistaHead
- Ribbons : 131
2011/03/01 13:10:30
Test each stick individually in the black slot farthest from the CPU (slot #3) CPU for 8 hours with a bootable CD of Memtest+. http://www.memtest.org/
gottex
2011/03/01 13:41:06
Ok, I started ! As u said, I set memory and processor for 1800 (3.6), mem 9-9-9-27 2T 1.8v
post edited by gottex - 2011/03/03 11:49:54
VistaHead
- Ribbons : 131
2011/03/01 13:47:55
Just so you are aware, I suggested testing your RAM in slot #3 because I recommend testing RAM in the slot that the motherboard manufacture recommends to use if you are running a single stick of RAM. The slot varies from manufacturer to manufacturer, and board to board. On the 790i SLI FTW (analog) board, the recommended slot for running one stick of RAM is slot #3, which is the second black slot.
gottex
2011/03/01 13:52:26
Done, already in there!
post edited by gottex - 2011/03/03 10:21:52
gottex
2011/03/02 11:24:24
One stick worked 10 hours 37 min - 0 errors Another one is running right now 4 hours 46 min - 0 errors (I think 6-7 hours will be enough) P.S. Just finished watching iPad 2 presentation ... nice, but I'm a Windows fan and I wish to have such tablet only with Win 7
post edited by gottex - 2011/03/03 10:22:45
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2011/03/02 13:36:50
Man, after all this time...I sure hope it all works out for you, Alex.
gottex
2011/03/02 13:37:50
Second stick 7 hours 15 min - 0 errors Now I start BLEND TEST in prime **Memory Timing Setting** Memory Timing Setting - [Expert] x tCL (CAS Latency) – 9 x tRCD - 9 x tRP – 9 x tRAS - 27 x Command Per Clock – 2T ** Advanced Memory Settings ** [Auto]. x tRRD [Auto] x tRC [Auto] x tWR [Auto] x tWTR [Auto] x tFAW [Auto] X RFC [Auto] x tREF 7.8 **Frequency Settings** CPU Freq, MHz – 3600 FSB Reference Clock, MHz – 1800 CPU Multiplier - [8X] EVGA VDroop Control [Without VDroop] CPU Core – 1.46875 CPU FSB – 1.425V Memory – 1.800V nForce SPP – 1.42V nForce MCP – 1.550V CPU PLL - 1.5V GTLVREF Lane 0 [Auto] GTLVREF Lane 1 [Auto] GTLVREF Lane 2 [Auto] GTLVREF Lane 3 [Auto] JeffreyHam Man, after all this time...I sure hope it all works out for you, Alex. I wanna to believe in it too )) hope it was REALLY ONLY A MEMORY ISSUE I know guys u all had enough of me  please, be just a little bit more patient and maybe I'll succeed and leave u alone
post edited by gottex - 2011/03/03 10:23:18
VistaHead
- Ribbons : 131
2011/03/02 14:14:11
gottex
2011/03/02 15:11:52
the outcome is the following: I ran BLEND TEST for 1 hour 38 min (gotta go now, so had to stop manually), passed 67-70 tests, 0 errors guess I have just a little tiny stability What is the next move ? Run BLEND for 8-12 hours?
post edited by gottex - 2011/03/03 10:21:20
gottex
2011/03/03 10:18:17
I guess all that time I used CoreTemp, I had wrong numbers ??? It shows wrong frequency and multi
post edited by gottex - 2011/03/03 10:20:55
VistaHead
- Ribbons : 131
2011/03/03 10:23:15
You have to setup CoreTemp to get correct temps. You need to enter the TJMax for your CPU. I would run Blend overnight to be sure. Please post a completed BIOS template of your current settings.
gottex
2011/03/03 10:30:53
VistaHead You have to setup CoreTemp to get correct temps. You need to enter the TJMax for your CPU. I didn't find this option
VistaHead
- Ribbons : 131
2011/03/03 10:34:31
gottex
2011/03/03 10:39:49
VistaHead I have not used CoreTemp in years. I use Everest Ultimate, which was bought out by AIDA64. If you install it, click Computer - Sensors, and all of your temps will be located there. http://www.aida64.com/product/aida64-extreme-edition/overview I attached pic above, I have it, and the temp are mostly the same with RealTemp (TjMax set manually to 90) If you read this article, u may find that TjMax for my chip is 80C, but I'm not sure if this data is valuable or true. Many disputes about that in internet (Googled for some forums) So now I'll use AIDA64 as it seems to me it shows the most correct info for temps
post edited by gottex - 2011/03/03 11:14:30
gottex
2011/03/03 11:21:38
VistaHead I would run Blend overnight to be sure. Please post a completed BIOS template of your current settings. I also attached a pic of my idle temps **Frequency Settings** CPU Freq, MHz – 3600 FSB Reference Clock, MHz – 1800 CPU Multiplier - [8X] PCIe x16_1 & 16_2, MHz - 100 PCIe x16_3, MHz - 100 SPP<->MCP Ref Clock, MHz - 200 **HT Multiplier** nForce SPP --> nForce MCP - [5 x] nForce SPP <-- nForce MCP - [5 x] **Spread Spectrum** CPU Spread Spectrum - [Disabled] HT Spread Spectrum - [Disabled] PCIe Spread Spectrum(SPP) - [Disabled] PCIe Spread Spectrum(MCP) - [Disabled] SATA Spread Spectrum - [Disabled] **FSB & Memory Config** EPP 2.0 Memory [Disabled] FSB – Memory Clock Mode - [Linked] FSB – Memory Ratio - [Sync Mode] FSB (QDR), MHz - [1800] Actual FSB (QDR), MHz - 1800 x MEM (DDR), MHz - [Linked] Actual MEM (DDR), MHz - 1800 P1 - [Enabled] P2 - [Enabled] **Memory Timing Setting** Memory Timing Setting - [Expert] x tCL (CAS Latency) – 9 x tRCD - 9 x tRP – 9 x tRAS - 27 x Command Per Clock – 2T ** Advanced Memory Settings ** [Auto]. x tRRD [Auto(6)] x tRC [Auto(45)] x tWR [Auto(12)] x tWTR [Auto(19)] x tFAW [Auto(29)] X RFC [Auto(110)] x tREF 7.8uS - set manually, cause on AUTO it sets 7.7 **System Voltages** EVGA VDroop Control [Without VDroop] CPU Core – 1.46875 CPU FSB – 1.425V Memory – 1.800V nForce SPP – 1.42V nForce MCP – 1.550V CPU PLL - 1.5V GTLVREF Lane 0 [Auto] GTLVREF Lane 1 [Auto] GTLVREF Lane 2 [Auto] GTLVREF Lane 3 [Auto] **CPU Configuration** Limit CPUID Maxval - [Disabled] Intel SpeedStep - [Disabled] xPPM Mode - [Native] CPU Thermal Control - [Disabled] C1E Enhanced Halt State - [Disabled] Execute Disable Bit - [Disabled] Virtualization Technology - [Disabled] CPU Core 0 - [Enabled] CPU Core 1 - [Enabled] CPU Core 2 - [Enabled] CPU Core 3 - [Enabled]
post edited by gottex - 2011/03/03 11:26:59
VistaHead
- Ribbons : 131
2011/03/03 11:36:04
gottex
2011/03/03 11:49:04
VistaHead Looks good! So now I need to run BLEND for 8-10 hours with this settings ? If I pass without errors, should I run for "In-place large FFT's", LinX 0.6.4 - 20 tests, OCCT 3.1.0 - priority normal, matrix (middle) ??? And I didn't quite get how to make Core 1 and Core 2 finish first
VistaHead
- Ribbons : 131
2011/03/03 12:12:05
If it were me...and I repeat...if it were me, I would run blend for about 8 hours, and should I encounter no issues, I would enjoy my PC. IMHO, some folks "test for stability" too much...like I said...IMHO.
