JeffreyHam
R.I.P. Friend
- Ribbons : 126
Re:790i FTW and qx6850 - need overclock help
2010/08/31 11:58:58
Man; I must be honest, I am very puzzled over this and running out of ideas. It sure couldn't hurt to give danno's suggestions a try. I never did find any info in regards to possible issues running a 2GB video card...let alone 2 of them...on the 790i MoBo. I do know that everyone I have communicated with on here, that has an Extreme CPU, has had issues getting things to run correctly.
PLEASE REMEMBER TO UPLOAD A COPY OF YOUR INVOICE = My Current Linked and Synced Settings All detailed system components are listed on my Mods Rigs page.
gottex
2010/08/31 12:16:25
jeffreyham Man; I must be honest, I am very puzzled over this and running out of ideas. It sure couldn't hurt to give danno's suggestions a try. I never did find any info in regards to possible issues running a 2GB video card...let alone 2 of them...on the 790i MoBo. I do know that everyone I have communicated with on here, that has an Extreme CPU, has had issues getting things to run correctly. Well what I learned from u guys, extreme chips are more complicated then normal, I'll give a try danno's suggestion, if it won't work I'll stay on default, guess there is no luck 4me to have OC system stable :) like we say in Russia "if your hands grow not from a right place, better stay default" ;-)
CPU: Intel QX6850@3.6Ghz (1.45625v) Motherboard: EVGA 790i SLI FTW (bios SZ17) Video: Tri-SLI MSI N580GTX-M2D15D5 772MHz/4008MHz Memory: Kingston HyperX KHX1800C9D3K2/4G, DDR3 4Gb PC3-14400 1800MHz, 9-9-9-27 (2T) 1.8v HDD1: WD VelociRaptor 150Gb SATA-II 10000rpm HDD2: WD VelociRaptor 300Gb SATA-II 10000rpm HDD3: WD 1002FBYS 1Tb SATA-II 7200rpm PSU: Enermax Galaxy EVO 1250W Revolution 85+ Case: Cooler Master Stacker 832 OS: Windows 7 64-bit Water cooling: XSPC RX480; Koolance PMP-450; XSPC Acrylic Dual 5.25" Bay Reservoir for Laing D5; Koolance CPU-370; Bitspower BP-WBN79NS-BK; Bitspower BP-WBN79AP1-BK & BP-WBN79AP2-BK
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2010/08/31 12:25:06
 That is good. Is it possible for you to try a different GFX card to see if the same issues happen on it? Do you have an old spare or can you borrow one from a friend?
gottex
2010/08/31 12:29:31
jeffreyham That is good. Is it possible for you to try a different GFX card to see if the same issues happen on it? Do you have an old spare or can you borrow one from a friend? I have one XFX 8800 Ultra ... should I run it on OC system ? 1800 or 1600 FSB ?
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2010/08/31 12:37:14
Try it on both. Your system should have no problem at all running stable at 1800MHz.
gottex
2010/08/31 12:44:23
jeffreyham Try it on both. Your system should have no problem at all running stable at 1800MHz. ok, I'll try it tomorrow and post back thank you !!!
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2010/08/31 12:49:17
Allright man....I'll be looking forward to knowing your results. You are welcome, my friend....have a good one.
gottex
2010/09/07 14:02:30
jeffreyham Allright man....I'll be looking forward to knowing your results. You are welcome, my friend....have a good one. Hey man! sorry for being out for so long, had some work ... about my stability ... NOTHING :( Guess I'm damned with this chip :(
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2010/09/07 16:14:42
No problem...I figured that you have been real busy. I am sorry to hear that you have not been able to get a stable OC on your system. At this point, I find myself at a loss for what to try next. I have no idea if it is your CPU, RAM or a combination of them both that is causing the issue. I guess that you'll just have to set it where it is the most stable. In the meantime...maybe someone else reading this will provide you with some more ideas.
Ex0duS_5150
2010/09/09 09:51:07
gottex Hello guys First I'm sorry for my English I'm trying to get stable 3.6 at least (donno about 3.8 yet) Well here is what I got LinX 0.6.4 - passed 20 tests without errors, 41 min 34 sec OCCT 3.1.0 - passed one hour, priority normal, matrix (middle), no errors Prime95 v.25.11 build 2 64bit - 11 hours, In-place large FFT's (maximum heat, power consumption, some RAM tested), Advanced - Round off checking CHECKED Temps were measured with Core Temp 0.99.7, under load 66-69 on all cores Temps idle - Core 0 - 47; Core 1 - 45; Core 2 - 44; Core 3 - 44; SPP - 44; MCP - 32 guess its stable except games, I got freezes after playing every 10-15 min, then Alt+Tab and back, and its normal again Hope for your advice Hi guys just had to put in my 2cents as im still waiting on my 2nd RMA'd 9800GX2 and have nothing else better to do.. Seems to me your temps are a little high for idle at 3.6.. Im on air and i idle at 35c to 40c, 40 to 45 across the board on a hot day.. Load temps never see 73c with IBT 20 passes at max setting.. Your now going for 4Ghz on 1800 Mhz FSB? Im sure your load temps are going crazy now, what are they BTW? You guys ever think heat at this point might be an issue? Im not 100% sure but even lowering the multi on the CPU but still pumping 1800MHZ threw it still raises heat.. What kind of CPU cooler are you using and again, what are your 100% load temps at 1800MHZ FSB??
post edited by Ex0duS_5150 - 2010/09/09 09:55:31
|| I7.2600K@4.7Ghz 24/7-1.376v 10Hrs PrimeBlend stable || 2x4 gigs G-Skill F3-14900CL9d 1866Mhz 1.6v 9-9-9-24-t1 || ASUS P8P67 PRO.B3 || ASUS GTX780oc@1280Mhz boost 7500Mhz ram on a BenQ XL2720T || 2xs 120 gig Corsair GT III ssd in Raid 0,SaTa W.D.Raptor 150, W.D.500 gig storage || Cooling: Noctua 6-d14 || 1200w Corsair atx || Win7 64 bit Ultimate ||
gottex
2010/09/13 10:15:04
jeffreyham No problem...I figured that you have been real busy. I am sorry to hear that you have not been able to get a stable OC on your system. At this point, I find myself at a loss for what to try next. I have no idea if it is your CPU, RAM or a combination of them both that is causing the issue. I guess that you'll just have to set it where it is the most stable. In the meantime...maybe someone else reading this will provide you with some more ideas. Hello my friend, sorry for disappearance, work work work ... ;) I still testing 3.6, but no luck ... system stable for everything but not games, keep getting freezes, only when everything on DEFAULT no prob at all, I even tried one 480 video - no luck. Guess I'll start saving for normal i7 system ;) Ex0duS_5150 Hi guys just had to put in my 2cents as im still waiting on my 2nd RMA'd 9800GX2 and have nothing else better to do.. Seems to me your temps are a little high for idle at 3.6.. Im on air and i idle at 35c to 40c, 40 to 45 across the board on a hot day.. Load temps never see 73c with IBT 20 passes at max setting.. Your now going for 4Ghz on 1800 Mhz FSB? Im sure your load temps are going crazy now, what are they BTW? You guys ever think heat at this point might be an issue? Im not 100% sure but even lowering the multi on the CPU but still pumping 1800MHZ threw it still raises heat.. What kind of CPU cooler are you using and again, what are your 100% load temps at 1800MHZ FSB?? Do you have WITHOUT or WITH VDROOP ??? Cause when u set WITHOUT ... temps r much higher ... I can't even pass a single test on 1800 ... get immediate BSOD, as I posted before, system fully stable only on 1600, BUT NOT FOR GAMES Ex0duS_5150 What kind of CPU cooler are you using Corsair Hydro H50
post edited by gottex - 2010/09/13 10:22:37
danno428cj
2010/09/13 10:58:58
set your FSB to 1575 and check stability.
Gigabyte Z77 G1 Sniper3 LGA 1155 Intel Core i7-3770k @ 4.2 G.Skill Ripjaws X Series 8GB (2X4GB) PC3 14900 @ 1866 EVGA GTX 780 Classified ACX Western Digital Caviar Black 1TB RAID 0 Silverstone Strider Gold 1000w Coolermaster HAF-932 case.
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2010/09/13 12:10:16
Hey there, Alex....work, work, work...I figured as much. I hope that you are doing well. I also hope that someone can give you an idea to try that will work for ya...because, I am still at a loss here....and I am very sorry about that. I keep checking to see. Later on, my friend.
2010/12/02 19:49:30
Hey man...I have your system, kinda. Need some tips? PM me! @ 3.8 I had max load prime95 62-64 during the Hot and humid summer Idle was 28-32, each core within 1-2 deg of that with my H50.
post edited by Peter Northbridge - 2010/12/02 20:02:31
Classified3E770-i7960 @ 4.2 -ApogeeXT-MCR220- MCB120 Rev.2-MCRES Micro Rev.2-MCP655B XPS720 Case-custom BTX to ATX mod-Mountain mods black anodized EATX tray-GTX580 850/2100-12GBXMS3 @ 2005 RevodriveX2 240GB-WD2TB-WD1TBx2-OCZ ZX 1000W- Logitech K800/G13/G27-Steel series XAI -LG 2753V-
gottex
2010/12/16 14:28:54
Peter Northbridge Hey man...I have your system, kinda. Need some tips? PM me! @ 3.8 I had max load prime95 62-64 during the Hot and humid summer Idle was 28-32, each core within 1-2 deg of that with my H50. First of all I wanna apologize in front of all the readers for not responding to the thread, had to stay in China for a while for work without my "little beast"  ... now I'm back in Moscow, yahoo Donno whats with my system, cause u probably read everything I posted here and I can't get stable, many many many thanx to my friend JeffreyHam for his patience and help, but I guess I'm just a noob in OC My idle temps are: 46 44 42 43 in Prime max load are: terrible, posted before ... over 60 and sometimes 70, even H50 is not enough for cooling in hard tests ...
post edited by gottex - 2010/12/16 14:43:34
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2010/12/16 16:03:12
Welcome back, Alex!!!  I sent you a PM reply. Those MAX Load temps really, are not that bad. Maybe Peter Northbridge will have some helpful input for you.
2010/12/19 19:52:30
Ok...your temps seem okish..idle for me is 29-33 deg c, prime 95 load I get to 72, TJ max of 90, FYI. My current Setup is 3.7GHZ, I've had It all over the place with lots of stability. Currently FSB 462 * 8 Ram link and sync @ 1850, 8-8-8-24, 2T Ram @ 1.9v, stock is 1.8...running my ram a slight bit higher on the Volts should also add some stability, however I have a good airflow situation, I'm not concerned about heat. My Ram, OCZ Flex, is very good all over the place, up to 2000 @ 999-30 2T, so I will have some more success than you in that dept. Vcore 1.464, Vdroop obviously off. The corsair H50 is ok, not necessarily a pro H2O cooler, but it's good. We have a 65nm Chip, it gets hot, requires volts. The H50 has a CRAP, i repeat CRAP polish on it. Get some Mag wheel polish if you dont like the sand paper route and polish it a bit. In 5 minutes and a bit of elbow grease, you will improve it greatly, also buy some good thermal paste. 10 bucks + elbow grease is cheap all things considered. Blow out your radiator with compressed air, as well. They hold more than the usual amount of dust due to the amount of little fins they have, so clean it regulary, once a month is a great idea. Also let it < the rad> get fresh air...Try a different mounting position? If you need tips on howto polish it to a mirror or just a shine..ask. This will improve temps. If you need help getting stability @ a certain point, ask, too! I have screenshots from several stable places, up to 3.94 using a 9 multi. I found that past the 1.47Vcore range and the 1850ish FSB I was getting my temps past where I was comfortable with, which is 75 Max per core, SPP 60, MCP 65.....I'm not really going to go past those temps, that's where I draw the line. To get this chip to 4ghz, you'll need more than a corsair H50, it's just a cheap cooler. you will also need to cool the Chipset a bit better than the stock unit. Ive removed, cleaned and thermal pasted all my heatsinks, as well. That said, I have an 1850 mhz FSB Quadcore cooled adequately for $60! Your call if that's good or not. I'll give you a full bios template if you like as well, just thought Id give you my two cents first! :p I check this ten times a day, I'm in the line for the 580 stepup, 724th place :( So I may be quick to reply if you need help. Good luck!
post edited by Peter Northbridge - 2010/12/19 19:58:51
2010/12/19 20:20:46
What I would merely suggest is setting your FSB to 1800, work with an 8 multi. 9, you're going too far, will require over 1.5Vcore, your temps will obviously be higher. That would put you in a stable spot almost off the bat, having your Ram and FSB @ 1:1 is butter, you can do that, presumeably, so, give it a try. maybe boost the volts to your ram, you will be running them @ their limit. That's 3.6GHz there, you won't really need much Vcore for that, maybe just some more Voltage on the FSB and SPP. Try 1.45Vcore, link & sync your RAM, manually set the timing, P1 & P2 enabled as well. That's a simple overclock to 3.6, however your FSB, which effects system performance the most, will be up from 1333 to 1800. There will be a noticeable performance increase from that and you should be able to pass all the prime tests you want @ good temps. Setup prime95 to do a custom test, on the bottom right, set the size to half your RAM, say 2048, so you can still use your system while it's testing and not have it lock up. Give that a try, if you like..any other settings you need to apply have already been covered, but if you need to , ask away! Something else you may want to try, went thru the posts to see if anyone suggessted it....Do a clean install of your O/s @ the default hardware settings, 3.0, 1333, ram at stock...put everything on auto if you must...install windows. Install CPU-Z, prime95, everest or HW monitor, set your TJ max to 90deg. c within either of the temp. monitoring progs. Install your chipset drivers, video card drivers, get all the windows updates, turn off UAC, set the power management settings within windows so the PC wont goto sleep or hibernate......Then start there. Do this on a seprated HDD if you got one, make a dedicated O/S for overclocking. Dont put anything else on it other than what you need to run windows and stability/temp tests. Then goto your bios and start ye olde overclock. Just another way to eliminate any other possibilities that will give you a BSOD or something. Theere are lots of other benefits of having a dual boot PC or two O/S choices so it's generally a good idea regardless of what you're doing. Ive marked in red a few things to try HTspread spectum Disabled PCIespread spectum SPP Disabled PCIespread spectum MCP Disabled SATAspread spectum Disabled CPU Freq, MHz – 4050 will change to 3600 FSB Reference Clock, MHz – 1800 CPU Multiplier - [9X] change to 8 PCIe x16_1 & 16_2, MHz - 100 PCIe x16_3, MHz - 100 SPP<->MCP Ref Clock, MHz - 200 **HT Multiplier** nForce SPP --> nForce MCP - [5 x] nForce SPP <-- nForce MCP - [5 x] **FSB & Memory Config** EPP 2.0 Memory [Disabled] FSB – Memory Clock Mode - [Linked] FSB – Memory Ratio - [Sync Mode] FSB (QDR), MHz - [1800] Actual FSB (QDR), MHz - 1800 x MEM (DDR), MHz - [Linked] Actual MEM (DDR), MHz - 1800 P1 - [Enabled] P2 - [Enabled] **Memory Timing Setting** Memory Timing Setting - [Expert] x tCL (CAS Latency) – 8 x tRCD - 8 x tRP – 8 x tRAS - 24 x Command Per Clock – 2T ** Advanced Memory Settings ** [Auto]. Leave em all on auto **System Voltages** EVGA VDroop Control [Without VDroop] CPU Core – 1.5000 change to 1.46 CPU FSB – 1.350V change to 1.425 - You're up in the range of your max FSB @ 1800, so having the FSB up near where intel says it's the max is a good plan. Memory – 1.800V change to 1.9 - You will be using your RAM @ it's full potential, if you have a moderate amount of airflow over your RAM, this small Voltage increase will not kill it, of course I'm not giving you a personal warranty, either. :P nForce SPP – 1.37V change to 1.42, if you pass tests, we will try to lower this after nForce MCP – 1.550V leave this, seems adequate CPU PLL [Auto] 1.5V leave this as well, just put in the value manually. GTLVREF Lane 0 [Auto] +75mv set to 0 GTLVREF Lane 1 [Auto] +50mv set to 0 GTLVREF Lane 2 [Auto] +00mv set to + 50mv GTLVREF Lane 3 [Auto] +00mv set to + 50 mv The GTLVREF will be tuned a bit later, just manually set them to this for starters...once prime 95 is running properly, you can tailor it a little to get core 0 or core 1 to pass first..this is just a quick setup to get you to a stable 3.6, 450 * 8, 1800 FSB. Should be very easily obtainable with your system. So...aside from your RAM being different, your timings will be a little off of mine, your setup will be identical to mine, you should have stability here. 3.6ghz, 1800FSB. Put both your Vid cards in, not the physX card, dont overclock them, just do the drivers Do your stress testing on your new O/S and see where that takes you. . Basically overclock with the bare minimum you need to have your system fully functional. Then do your add ons, PhysX card, sound card, whatever you have. . Overclock your cards to your liking..I use the same as you, MSI afterburner and the EVGA OCCT to test. Once you have all your hardware where you want it..then do all your software. Sound like a plan? You will be starting over from scratch with this method but during the process of you doing all this, you will also be able to identify what it is that's holding you back/causing BSOD by doing it all in steps. I'd recommend doing it all with one stick of ram and one vid card but really, you're not going for a record OC, your hardware should take it.
post edited by Peter Northbridge - 2010/12/20 13:29:43
gottex
2010/12/20 22:52:03
Peter Northbridge Ok...your temps seem okish..idle for me is 29-33 deg c, prime 95 load I get to 72, TJ max of 90, FYI. My current Setup is 3.7GHZ, I've had It all over the place with lots of stability. Currently FSB 462 * 8 Ram link and sync @ 1850, 8-8-8-24, 2T Ram @ 1.9v, stock is 1.8...running my ram a slight bit higher on the Volts should also add some stability, however I have a good airflow situation, I'm not concerned about heat. My Ram, OCZ Flex, is very good all over the place, up to 2000 @ 999-30 2T, so I will have some more success than you in that dept. Vcore 1.464, Vdroop obviously off. The corsair H50 is ok, not necessarily a pro H2O cooler, but it's good. We have a 65nm Chip, it gets hot, requires volts. The H50 has a CRAP, i repeat CRAP polish on it. Get some Mag wheel polish if you dont like the sand paper route and polish it a bit. In 5 minutes and a bit of elbow grease, you will improve it greatly, also buy some good thermal paste. 10 bucks + elbow grease is cheap all things considered. Blow out your radiator with compressed air, as well. They hold more than the usual amount of dust due to the amount of little fins they have, so clean it regulary, once a month is a great idea. Also let it < the rad> get fresh air...Try a different mounting position? If you need tips on howto polish it to a mirror or just a shine..ask. This will improve temps. If you need help getting stability @ a certain point, ask, too! I have screenshots from several stable places, up to 3.94 using a 9 multi. I found that past the 1.47Vcore range and the 1850ish FSB I was getting my temps past where I was comfortable with, which is 75 Max per core, SPP 60, MCP 65.....I'm not really going to go past those temps, that's where I draw the line. To get this chip to 4ghz, you'll need more than a corsair H50, it's just a cheap cooler. you will also need to cool the Chipset a bit better than the stock unit. Ive removed, cleaned and thermal pasted all my heatsinks, as well. That said, I have an 1850 mhz FSB Quadcore cooled adequately for $60! Your call if that's good or not. I'll give you a full bios template if you like as well, just thought Id give you my two cents first! :p I check this ten times a day, I'm in the line for the 580 stepup, 724th place :( So I may be quick to reply if you need help. Good luck! Thanx man, I'll give it a try on weekend ;)
2010/12/21 05:22:28
if you succeed with this, the next step will be to back off your voltages in small increments to lower your temps, etc....Keep me posted, tell me if you get into windows and prime95......When prime95 is running, use the custom test like I said, using half your available memory....If it fails, write down which worker stopped first, you might be able to get away with boosting the GTLVref on that particular Core <which is the worker> a few steps, or just boost the vcore one step. If you find yourself passing tests...Let's hope!....write down the "firing order" of your processor...which core finishes first...after 6 hours, core 0 does 250 tests, core 1 does 236, etc...Try to trim out the GTLVref up or down to get Core 0 or Core 1 to finish first then try to to get Core 2 and Core 3 to finish third and fourth. Maybe do a test for an hour just to get a glimpse of which core is doing the most tests and trim the GTLVref before you do your final 12-24hr test. You'll never get them all to work in unicin or like always 0,1,2,3. But you do want to try to get it at least close. You won't have a 5ghz record breaker but you will have a very snappy quad core hopefully after this is done, or a bill for a new PC. lol. I'm just building my new one, got the last Classified 3 E770 2 weeks ago from EVGA, getting an i7950, the 580 <yay>, 12GB corsair dominator 2000, not sure bout cooling yet tho. So, I'll be retiring/beating the #$%& out of this rig soon so if you want to know the limits of this hardware combo...I might find em for you lol. Good luck!
gottex
2011/02/12 14:22:37
Hey guys, sorry for being out of topic, business trips, so tired ... happy valentines day to all. Gotta start testing with your suggestions ... u all probably have i7 or i5 and get rid of old stuff, but I still have to deal with it, anyway, I'll promice to keep u posted on results Alex
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2011/02/12 19:36:18
Hey there, Alex...been a long time....hope you are doing well. No new stuff here except GFX card. I'm going to stay on my 790i until it dies before I change platforms. I hope you can still get yours stabilized.
2011/02/14 06:53:20
I was worried that I gave him "death to computer" advice lol but he PM'd me and explained he was out of the country. I'd say happy valentines day, too but my heart is broken due to the fact i'm still in line for the GTX 580 stepup lol.
gottex
2011/02/21 13:38:57
Hello my friends! sorry for keeping silence, so far I managed only polish a bit my H50 with russian paste GOI (special for polishing metal plates), I got thermal paste Arctic Silver CERAMIQUE for thermal interface. (too much work  ) I got new PSU for full stability - Enermax Galaxy EVO 1,250W Power Supply Revolution85+. Stock temps are: Core 0 46C (Idle) Core 1 43C (Idle) Core 2 40C (Idle) Core 3 40C (Idle) WITHOUT VDROOP next weekend I'll start OC is this temps are normal for idle without OC ? it too hot at my apartment, so I think I'll put my PC on the balcony while testing in OC, its -12C outside
post edited by gottex - 2011/02/21 13:57:21
JeffreyHam
R.I.P. Friend
- Ribbons : 126
2011/02/21 17:34:57
Those are a little high for idle temps but, should not hurt anything. You will definately want cooler ambient temp when you OC. I keep my computer room fairly cool in my apartment and idle temps are in the low 30's....under full OC'd load they get to high 60's/ low 70's. Yours will probably easily get into the upper 80's which will not be good.
2011/02/21 18:58:53
Nice PSU! Good choice on the paste as well! The paste also takes 150 - 200 hours of power cycling ( 2 -3 weeks of 10 hours on per day basically ) to fully cure...your temps were pretty much on the money for what mine were right after I put new paste on mine...now I'm idling@ 32 on the hottest core and 28 on the coldest. My motherboard temp sensor reads 29 usually....so you will see some improvement over time. Hope the OC works!!!!!
post edited by Peter Northbridge - 2011/02/21 19:19:07
gottex
2011/02/21 21:14:28
Still don't get it, why I can't get at least 40C idle (stock settings) on the hottest core while having same CPU and cooling Maybe not enough polish or maybe I spread not enough thermal paste ? Guess gotta keep trying, but the thing is, for almost 3-4 years with this chip, I never saw the temps that low (40 idle), only in winter (-15C outside) if I open all windows in my room. So 45-46C idle for the hottest core is real progress for me with H50 processor cooling P.S. Just went through my older posts and I see no improvements in temps  , the hottest core remain the same, only Core 2 and Core 3 dropped on 2-3C. Either I really have "special  " model of everything and it does make me "the lucky one  " or I totally do smth. wrong
post edited by gottex - 2011/02/21 23:15:37
2011/02/22 07:33:51
No no, you don't have the special model. Thermal Paste takes 150-200 hours to cure so your temps will go down but not right away. So far, I do not think you've done something wrong, without me being there, of course! :P Does your computer have good airflow into and out of itself? Is there anything blocking the exhaust? Last time I thermal pasted my CPU, I had idle temps of around 40 per core, and they went down to 30 and sometimes less after my paste cured!
post edited by Peter Northbridge - 2011/02/22 08:10:57
2011/02/22 08:10:28
Currently My cores are 34c on the hottest and 29 on the coldest. I have an excellent airflow situation as well...my case is a ridiculously effective windtunnel, my computer is on the floor in a cold basement. If I put my PC on my desk, my temps all go up by over 10%. When I take my PC to my friends house to play games, my temps are where yours are as well, his ambient room temp is high, there are 7 computers and 4 people in the room we play in lol. So, really Alex your temps aren't what I would call terrible and they aren't great, either. But they are right about where they should be with your equipment and there are quite a few variables that can change them. The OC I gave you the steps to go for isn't a record breaker either, you shouldn't have a crazy increase when we're done, hopefully..considering they will improve when your thermal paste cures. The thermal paste: If you think you've done a bad job with it, there's a few things you can do. Application - A few ways to do it....Placing one line diagonally across the chip then using a plastic spreader to evenly spread the paste on the chip. you need some experience doing it this way, there's the chance you can spread it too thin, leave a bald spot like the one on my head, etc. :P You can place a large drip of it on the center of the chip, then during the installation of your chosen heatsink you spread it using the heatsink...still both of these methods only work if there's enough paste...Be liberal with it...just don't put too much on. The h50 is pretty easy to remove without taking the whole PC apart...I used double sided tape to gold the backplate on my motherboard when I installed the h50, so if you've done the same, you can simply undo the 4 screws holding down the h50 to your CPU just enough to get the retention ring lose so that you can hold the h50 in your hand and twist it a bit back and forth (without being terribly aggressive with it) to spread the thermal paste across the cpu and h50. It only takes all of 30 seconds to do this so, get your computer warm first ( so that the thermal paste is a bit easier to work with ), just boot it up, use it for a bit then power it off, then do your work. Sometimes it's a good idea to do this after a few days after you do a thermal paste job anyways to ensure that you have the chip covered adequately. Again though 150-200 hours of power cycling is needed to cure the paste so your true temps won't be revealed until that time has passed.
gottex
2011/02/25 09:00:40
Ok here I am again So I downloaded latest version of Prime95 v.26.5 build 5 (last updated February 22, 2011) Did some Custom tests as you told me with half RAM (all boxes unchecked) and every time my Workers STOPPED on the 1st test ... The following "STOPPED WORKERS" order (tried 2 times) : 3 - 2 - 4 - 1 ; 2 - 4 - 3 - 1 Then I went for BLEND test (tried 2 times), also stopped on 1st test : 3 - 2 - 4 - 1; 2 - 4 - 3 - 1 (also some times it was different) And the only test I can run without STOPPING WORKERS is "In-place large FFT's" but here I got the following WORKER FINISH order : 2 - 4 - 3 – 1; 3 - 4 - 1 - 2 and so on. I’ve been running it for a 30-40 min already ... If you ask me about the temps, I'll answer - its cold  , because I set my PC in the balcony and its -10C outside  , so right now I run "In-place large FFT's" and its 51C each core under load ... I'll leave my PC there while I run tests, cause its really hot inside, about +27C, H50 won't cool the processor in such ambient temp. So the settings are : **Frequency Settings** CPU Freq, MHz – 3600 FSB Reference Clock, MHz – 1800 CPU Multiplier - [8X] PCIe x16_1 & 16_2, MHz - 100 PCIe x16_3, MHz - 100 SPP<->MCP Ref Clock, MHz - 200 **HT Multiplier** nForce SPP --> nForce MCP - [5 x] nForce SPP <-- nForce MCP - [5 x] **Spread Spectrum** CPU Spread Spectrum - [Disabled] HT Spread Spectrum - [Disabled] PCIe Spread Spectrum(SPP) - [Disabled] PCIe Spread Spectrum(MCP) - [Disabled] SATA Spread Spectrum - [Disabled] **FSB & Memory Config** EPP 2.0 Memory [Disabled] FSB – Memory Clock Mode - [Linked] FSB – Memory Ratio - [Sync Mode] FSB (QDR), MHz - [1800] Actual FSB (QDR), MHz - 1800 x MEM (DDR), MHz - [Linked] Actual MEM (DDR), MHz - 1800 P1 - [Enabled] P2 - [Enabled] **Memory Timing Setting** Memory Timing Setting - [Expert] x tCL (CAS Latency) – 8 x tRCD - 8 x tRP – 8 x tRAS - 24 x Command Per Clock – 2T ** Advanced Memory Settings ** [Auto]. x tRRD [Auto(7)] x tRC [Auto(46)] x tWR [Auto(12)] x tWTR [Auto(19)] x tFAW [Auto(35)] X RFC [Auto(110)] x tREF [Auto] **System Voltages** EVGA VDroop Control [Without VDroop] CPU Core – 1.46250 CPU FSB – 1.425V Memory – 1.800V nForce SPP – 1.42V nForce MCP – 1.550V CPU PLL - 1.5V GTLVREF Lane 0 [+0mv] GTLVREF Lane 1 [+0mv] GTLVREF Lane 2 [+50mv] GTLVREF Lane 3 [+50mv] **CPU Configuration** Limit CPUID Maxval - [Disabled] Intel SpeedStep - [Disabled] xPPM Mode - [Native] CPU Thermal Control - [Disabled] C1E Enhanced Halt State - [Disabled] Execute Disable Bit - [Disabled] Virtualization Technology - [Disabled] CPU Core 0 - [Enabled] CPU Core 1 - [Enabled] CPU Core 2 - [Enabled] CPU Core 3 - [Enabled]
post edited by gottex - 2011/02/25 09:19:34
