750i cpu fan speed.
6dracing
2010/09/14 19:55:40 (permalink)
Hello,
Sorry if this has been posted before.  I have an evga 750i ftw motherboard and was wondering if there is a way to adjust the cpu fan speed from the bios.  Mine is plugged directly into the board on the cpu fan port.  Any suggestions???
24 Replies Related Threads
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/14 20:18:31 (permalink)
    Use "Dynamic Fan Control"
    post edited by XrayMan - 2010/09/14 20:20:53
    My Affiliate Code: 8WEQVXMCJL
    6dracing
    Re:750i cpu fan speed. 2010/09/14 20:35:09 (permalink)
    I found that in the bios.  I set it to manual but the fan speed stayed the same......something im doing wrong, or my cpu fan isnt compatible?
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/14 20:52:02 (permalink)
    6dracing
    I'm not sure. It should work. Would you consider using SpeedFan? Alot of people use it to control fan speeds. You can download it here> http://www.almico.com/sfdownload.php
    JeffreyHam
    R.I.P. Friend
    • Ribbons : 126
    Re:750i cpu fan speed. 2010/09/14 21:07:11 (permalink)
    After you set it to manual did you make sure it was set on 100%? I believe that if your cooler only has a 3-wire plug in on it, that you cannot control it this way....needs to be a 4-wire to do it.
    post edited by jeffreyham - 2010/09/14 21:10:14
    PLEASE REMEMBER TO UPLOAD A COPY OF YOUR INVOICE
       = My Current Linked and Synced Settings
    All detailed system components are listed on my Mods Rigs page
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/14 21:24:58 (permalink)
    jeffreyham
    Ah yes. I forgot about that. > "4 pin connector enables fan speed control. 3 connector just enables fan speed sensing".
    Thanks for correcting me! Bad Jeff!  Good job Jeff!
    post edited by XrayMan - 2010/09/14 21:30:06
    JeffreyHam
    R.I.P. Friend
    • Ribbons : 126
    Re:750i cpu fan speed. 2010/09/14 21:29:14 (permalink)
    I was right??? Kool!!!!
    6dracing
    Re:750i cpu fan speed. 2010/09/15 08:05:53 (permalink)
    Awesome,  Thats what I figured.  I will try and get one with 4 pin.
    JeffreyHam
    R.I.P. Friend
    • Ribbons : 126
    Re:750i cpu fan speed. 2010/09/15 11:13:17 (permalink)
    jeffreyham
    We wuz both right, Man!!!!!!
    6dracing
    Re:750i cpu fan speed. 2010/09/15 13:52:44 (permalink)
    bof of yous was right
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/15 22:20:43 (permalink)
    jeffreyham
    jeffreyham
    *Just thought of something. If they wanted to give a BR for this thread, they couldn't. They can't split a BR in two. Half for you, and half for me. Not even RJ, Nordic, or Tweaked could perform that kind of magic!
    post edited by XrayMan - 2010/09/15 22:32:57
    6dracing
    Re:750i cpu fan speed. 2010/09/16 09:35:47 (permalink)
    Out of curiosity, how do you give a blue ribbon,  Ill give you a thumbs up since I dont know how
    roche
    Re:750i cpu fan speed. 2010/09/16 12:05:14 (permalink)
    So with a 3 pins fan, the fan is always running at 100% .
    Correct ?
    quadlatte
    • Ribbons : 32
    Re:750i cpu fan speed. 2010/09/16 15:19:01 (permalink)
    roche
    Correct ?
    that is correct. you would need a four pin pwm fan for MB control. for 3 pin you could use a external fan control though if you like. and to request a blue ribbon for some one just send a pm to a mod
                                                 Heatware: http://heatware.com/eval.php?id=72498
    roche
    Re:750i cpu fan speed. 2010/09/16 16:57:45 (permalink)
     Thanks for your answer qualatte.
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/16 21:33:37 (permalink)
    6dracing
    At the present time, there's 2 ways of doing this. You can either PM a Mod directly, or use the "Report Abuse" button, and use that button to request BR's. At the moment that button can be used universally. I believe they may be working on a solution to rename that button, so it can be used for both.
    PS: Thanks for suggesting BR's for Jeffreyham and Myself from our earlier posts. We try to help out where we can. Take care!
    post edited by XrayMan - 2010/09/16 22:15:07
    JeffreyHam
    R.I.P. Friend
    • Ribbons : 126
    Re:750i cpu fan speed. 2010/09/16 23:05:14 (permalink)
    @ XrayMan: I was not trying to correct you...sorry if I came across that way.
    @OP roche: make sure that you mark the posts as helpful by clicking on that button in the bottom-right corner of each individual one. That will help to draw the Mods attention.
    @ quadlatte: thankx for your helpful contribution
    3 BR's on 1 thread??? Is that possible??? I've not seen that happen yet.
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/17 19:44:35 (permalink)
    jeffreyham
    1)  @ XrayMan: I was not trying to correct you...sorry if I came across that way.
    2)  3 BR's on 1 thread??? Is that possible??? I've not seen that happen yet.
    1) No no. I know you were trying to help out. I was just joking around with you. Your too cool of a forum member to get mad at!
    2) You never know. Maybe one of the mods can make history. LOL!
    JeffreyHam
    R.I.P. Friend
    • Ribbons : 126
    Re:750i cpu fan speed. 2010/09/17 20:06:59 (permalink)
    jeffreyham
    Oh,Yeah.....I got a good laugh out of the bad Jeff/good Jeff, for sure. It was your "Thanks for correcting me" comment that had me worried. I was just adding my 2 cents to your good recommendation. I may question you about an answer sometime but, I respect you and would never try to correct you.
    post edited by jeffreyham - 2010/09/17 20:11:27
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/17 20:12:02 (permalink)
    No problem Jeff! I'm glad we got it sorted out. You were worried for nothing bro. Anyway, let's make a deal. If I'm ever mad at you for something, (Very Doubtful), then I will PM you with it. Ok Jeff? Take care man!
    JeffreyHam
    R.I.P. Friend
    • Ribbons : 126
    Re:750i cpu fan speed. 2010/09/17 20:16:03 (permalink)
    Hey, that works for me. You have a good weekend too.
    Did you tell your boy Happy B-Day for me?? I hope he had a good one.
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/17 20:18:41 (permalink)
    Yea, but during a weekday he can't have much fun, because he has school and homework. Tomorrow Saturday though, he can really have a good B-Day party. Anyways, cya around.
    quadlatte
    • Ribbons : 32
    Re:750i cpu fan speed. 2010/09/18 15:09:31 (permalink)
    this thread gives me the warm and fuzzies.
    #23
    • Ribbons : 92
    Re:750i cpu fan speed. 2010/09/18 23:20:19 (permalink)
    quadlatte
    #24
    JeffreyHam
    R.I.P. Friend
    • Ribbons : 126
    Re:750i cpu fan speed. 2010/09/18 23:33:20 (permalink)
    ROTFLMAO!!!
    #25
