5.1 Ghz i5 2500K using H60 With Temps! with bios settings! *updated*
cblaxx
Re:i5 2500k 4.5ghz H60 With temps 2011/06/13 19:59:16 (permalink)
hey there, very nice temps on your chip there.
have you experienced any kind of downclocking when your temps get up past 72C?
I have noticed my chip doing this with my H60. As soon as i opened the window and got cold air in, the temps dropped and the downclocking stopped.
I find it strange because i havnt seen anyone else having the same issue as me. i have turned of the thermal monitoring and all power saving features.
this is all while being loaded.
Rig Info:
I7 2700K stock clocks(for now)
Gigabyte P67A-UD7
Corsair Vengeance 4x4GB
EVGA GTX TITAN SC
Corsair AX1200
Custom Water Cooling
Corsair Obsidian 800D
#31
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 03:17:21 (permalink)
cblaxx
no downclocking here.. but linx work in units, and when done with a unit, it takes a few sek to start a new one, in that few secs my temps drops too ... but my clockspeed never drops! :)..
and ty! :).. i am very happy with my current setup and i am even cosidering going for the 5 GHZ
i still have the powersaving features on ;).. except the EPU which i disabled (Energy Processing Unit) and that saves power ^^ so i just turned that off to be safe ;)
#32
owcraftsman
  • Ribbons : 57
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 07:19:53 (permalink)
boredgunner
You might want to pick up a pair of Scythe GentleTyphoon AP-29s, you should get slightly less noise (especially if undervolted, they're great at it) and noticeably better temps.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_49&products_id=30013
The ones below will perform even better at the cost of four decibels.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_49&products_id=27970
boredgunner
Wow that CPU runs cool.  Are you using the stock fans on the H60?
boredgunner
Slipstreams have a lot of CFM but not much static pressure so they can't move much air through the rad.  The stock H60 fan has more pressure so it might actually be better the way you have it now, nevermind what I said before.
I got your PM. The reason I did not respond again is boredgunner nailed it and I felt nuff said so consider this a +1. You would do well to heed the advice. How you ended up with these http://www.scythe-usa.com/product/acc/026/sy1225sl_detail.html  I do not understand. The links he provided gave clear insight on the reason for his selections you should make careful note of. That is to say if you want the best performance from the H60.
Overall I'm very impressed with it's performance especially considering the cost vs performance factor and I will be curious to see how well it handles 5.0 whatever the setting it takes to get there. For me I think I will opt for the larger Rad of the H70 and seek to tweak it's over all performance using, again, the very good advice from boredgunner.
GL now lets see those 5.0 results
Phanteks Eclipse P400: | MSI Z170A G7 | 6700k 4.7x 1.345v H110iGTX | G.Skill F4-3000C15D-16GVR |2x EVGA 980 TI SC ACX in SLI | Samsung 950 Pro M.2 OS | WD2003FZEX Data | Corsair RM750i
Phanteks Enthoo Luxe: MSI Z87-G45 Gaming v1.9 bios | 4770k 43x1.24v XSPC Raystorm | G.Skill TridentX2133C9 2x8-16GB | MSI R9-290x Kyrographics Hawaii w/Active Backplate | 2x 250gb 840 EVO Raid-0 OS | WD20003FZEX (data) | Corsair HX850
Phanteks Enthoo Primo: | MSI Z97 Gaming 7 | 4790k 48x 1.254v EK-EVO | G.Skill TridentX2400C9 2x8-16GB | 2x Sapphire R9-290x ref (hynix) CF EK block Backplate & serial bridge | 2x 840 Pro Raid-0 OS | WD20003FZEX (data) | EVGA SuperNova 1000 G2
#33
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 07:42:03 (permalink)
owcraftsman
http://www.scythe-usa.com/product/acc/026/sy1225sl_detail.html i got these from a mate when i bought the H60! :).. didn't buy them, have to say thanx to HeThing on gifting me 4 of those! :)..
but i havn't bought anything else to get better performance! :)..
the main concern i have is the temps.. if it allready now runs 80 degrees at 4.8 i doubt i have the room to go 5.0.. but ofc i have to try.. I'll be back later with results..! :D..
will overclock today! :D.. take further notice that i may jump back to 4.8 if it gets too hot! :).. but i will give u screeens! :D
#34
owcraftsman
  • Ribbons : 57
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 07:55:11 (permalink)
Agreed 80+ is high certainly higher than most would want to run at 24/7 so that's a wise decision but that's at 100% load with LinX which will be the worst case scenario in terms of heat. Your focus needs to be refining the current setup. I've read just reversing the air flow to intake which takes advantage of the cooler air out side the case and of course top quality fans makes the biggest difference in overall performance. Two modification worth your consideration if your case it up to it.
#35
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 08:10:36 (permalink)
owcraftsman
my top and side fan aren't currently powered! :P.. so i could consider powering those up! :P..
i read somewhere that the sandy bridge chips aren't supposed to get over 72 degrees, but even my motherboard warns at 85 :/.. those two statements aren't lining up! :/..
#36
owcraftsman
  • Ribbons : 57
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 08:31:12 (permalink)
Tcase for the 2500 k is 72.6 but that is to say the max surface temp of the IHS of the proc itself. You would need a heat sensor attached there inorder to get an accurate reading. The CPU & each core temp you see reported by Core Temp etc are located under that and would naturally be higher than on the surface. No doubt heat kills and you are wise to be concerned but you should be safe for the limited time of a LinX run at under 85c TjMax is around 100C I believe. It will probably start to throttle at 90C, and completely shut itself off at 100C (or 98C) this is the protect mechanism built in the the proc which most don't like to temp fate that it will actually work. Further more if you are concerned I believe the LinX program can be set to shut down at the desired temp you indicate by default I think it's set to 100c or maybe it 90c not sure which but you can poke around the interface to be sure and set it up.
#37
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 10:53:56 (permalink)
i promised u all 5 ghz!.. so i went and did 5 ghz!! :D
#38
owcraftsman
  • Ribbons : 57
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 10:57:58 (permalink)
Congrats it must be nice to know your proc is up to it. staying posted for those temps.
We need a 5GHz club thread.........
#39
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 10:59:52 (permalink)
owcraftsman
i allready posted a pic in first post with temps and linx and cpu-z running 5 Ghz! ;D
i did need to go 1.4v vcore instead og 1.38v :P.. but thats fine.. doesn't seem to hurt my temps so much! :P
but yea we deffenently need a 5ghz Club! ;)..
post edited by IstBarP - 2011/06/14 11:02:03
#40
kody7839
  • Ribbons : 17
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 11:07:56 (permalink)
Those temps are getting high for only 1.4 vcore.
Are you looking to run it 24/7 that way?
#41
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 11:15:58 (permalink)
kody7839
it is only when running linx i get so high.. when just running games and doing normal stuff i am around 55 degrees..
dunno if it seems high, older cpu's could handle 1.4 and not getting so hot, but they didn't overclock as well!.. we are talking about 50% overclock here!.. and ofcause it will generate heat at 50% overclock!..
i don't know if i want to run it that way 24/7  yet... but might if the gaming temps is still the same.. or about the same.. but this is mostly for knowing how high i can go i guess? :P.. someone know the capabilities of this cpu? XD.. i am at 5 ghz and only bumbed the power up once or twice xD.. proberbly my H60 giving up before the 2500k! ;)
#42
owcraftsman
  • Ribbons : 57
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 11:32:49 (permalink)
Yep I see that now, all seems to be in great shape. That is a good chip you have there under 1.4vCore at 5.0 is fantastic, temp below 79c load even better and running 67GFlops also very good.
If Can you can run a Linx problem size of 25000 or there about 20 passes with those temps I'd call it a superb 24/7 clock. I'd also be wondering how much more that proc has in her.
Nice work and thanks for sharing. It would be nice to know all your settings if you feel up to it.
#43
kody7839
  • Ribbons : 17
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 11:36:45 (permalink)
Oh I'm not saying there is anything wrong with it, more implying I think you're reaching the limits of your cooling setup. If during your runs the temps hang around those numbers, I would back it down a bit. If it just spikes, probably nothing to worry about if you don't plan to go much higher.
I brought my i7-2600K up to 5.3ghz and my i5-2500K up to 5.4ghz before I stopped. Ran both with my Silver Arrow which did a great job, but was getting close to if not meeting it thermal dissipation threshold.
Now the 2500 sits under a Hyper 212 at 4.5ghz with temps in the mid 50's while folding. Creeps closer to 60 when the room temps climb on warmer days. The 2600 has the SA at 4.9ghz and temps are in low 60's.
LinX, IBT, and Prime95 will always test the limits and really work the cooling capacity. I use them for stability and then check to see what things look like after chugging on wu's to get my real readings.
#44
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 11:36:54 (permalink)
kody7839
yea, i guess i am coming closer to the maximum of my cooling device also!.. but i could improve by putting other fans on it! :P..
and nice with the 2500k going to 5.4! :D..
btw, my cooling handles 4.5ghz just as fine as the hyper u are using, but at 5 ghz i guess i am having some trubles, but i am in a hot room atm, cuz the weather outside is nice today actually.. if i open window i get better temps cuz my comp is just under the window! :D.. (we are going towards the cold nights here now! :P.. it is 9PM! ^^
owcraftsman
i am gaming right now, both to see temps, and test the overclock too! :)..
i will post my settings later, and it will be in first post! :).. dunno if i should take pictures of my bios or just write down the setting, first would be best right? :)..
and yea it is a good chip i guess... i read somewhere only 10 percent goes to 5 ghz! ;D
post edited by IstBarP - 2011/06/14 11:42:54
#45
owcraftsman
  • Ribbons : 57
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 12:19:01 (permalink)
I'd write down all changes you made to the bios only, avoiding any Auto or default settings.
#46
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 13:49:19 (permalink)
owcraftsman
done! :)
#47
endomorph
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 14:13:43 (permalink)
CPU PLL voltage seems a bit high.  I would be very careful with it.
And nice chip indeed!
#48
owcraftsman
  • Ribbons : 57
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 14:15:15 (permalink)
It's nice how you added all that in one spot of your 1st post anyone looking for tips on the H60 or even OCing the i7 2500 k to 5.0 will be pleased to see it.
#49
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/14 14:22:57 (permalink)
owcraftsman
i5 :P.. but yea indeed! :).. i think they will! :)...
endomorph
it is 1.8 standard so i don't think it is high :P.. could try reduce , but i i put it up one notch since i had to put up pll voltage to overclock my old rig! :)..
but i think this is sad http://www.overclock.net/intel-cpus/942368-i5-2500k-5ghz-air-pipe-dream.html ...
he uses 1.49v vcore to hit 5ghz! :P.. so i don't know, maybe i am lucky with my chip  ? :P..
and if i search google "5 Ghz i5 2500K using H60"
it finds the old name of this thread "*updated* i5 2500k running 4.8 ghz H60 with temps"
post edited by IstBarP - 2011/06/14 14:30:40
#50
ARCTIC_EAGLE
  • Ribbons : 22
Re:i5 2500k 4.5ghz H60 With temps 2011/06/15 13:59:35 (permalink)
well after redoing my Thermal Paste, adding a pull fan, and a side fan; I've got my temps to 57*C at a clock of 4.5Ghz under constant load (Folding@home). System Temp 35*C, GPU temp 53*C (clock 799/1598/1900). That's with the pull fan at lowest possible RPM,  at max RPM it goes "down" to 54*C.
#51
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/15 14:25:25 (permalink)
ARCTIC_EAGLE
much better! :).. hope u are happy with it! ;D..
btw i am at 5.1 ghz! :).. overclock to 5 ghz and join the club
http://forums.evga.com/tm.aspx?high=&m=1068719&mpage=1#1070482 !!
#52
ARCTIC_EAGLE
  • Ribbons : 22
Re:i5 2500k 4.5ghz H60 With temps 2011/06/15 14:36:44 (permalink)
IstBarP
ARCTIC_EAGLE
I am pretty happy with it but currently my room is only 68*F so when the heat comes back (as it is summer) that will go up a fair amount so I'm not really sure how much I improved it.
I will OC to 5ghz but EVGA crap BIOS only lets us get to 4.5-4.8ghz, I'm on the low range and only able to get 4.5
#53
JeffreyHam
R.I.P. Friend
  • Ribbons : 126
Re:i5 2500k 4.5ghz H60 With temps 2011/06/15 14:49:59 (permalink)
Awwesome!! I really want to win one of the P67 MoBo's now!!
PLEASE REMEMBER TO UPLOAD A COPY OF YOUR INVOICE
   = My Current Linked and Synced Settings
All detailed system components are listed on my Mods Rigs page
#54
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/15 14:50:31 (permalink)
ARCTIC_EAGLE
IstBarP
ARCTIC_EAGLE
then i am pretty happy with my Asus P8P67 motherboard.. didn't even have to adjust the PLL voltage since i have hit no multiplier wall yet! :P..
that to be said i guess 5.1 is the max for the H60!.. 86*C degrees on core number 3 :/.. (running linx).. but you can see pic in the 5 ghz club thread! :)..
it is as my CPU wants to go higher but my cooling is banging it's head against that wall now
but i guess instead of beeing sad i can't get higher i should go  that i made 5.1 ghz stable!! :P i will not update this thread with settings on how to go to 5.1 since i have only been at 5.1 for an hour an a half.. :P.. but when i am sure it is stable i guess i could update this thread further! :)
#55
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/15 14:51:42 (permalink)
JeffreyHam
+1 in my modrigs if u like! :)..
and btw, i really want to win something too! :P.. signed up for every possible competition and havn't won anything yet! :(.. not even crysis 2 :(
#56
Afterburner
  • Ribbons : 108
Re:i5 2500k 4.5ghz H60 With temps 2011/06/16 22:32:26 (permalink)
Good info Bor
#57
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/17 03:36:33 (permalink)
Afterburner
Good info Bor
thanks! :).. hope it will help someone overclock their 2500k too! :)..
#58
h3liumDK
Re:i5 2500k 4.5ghz H60 With temps 2011/06/17 04:17:33 (permalink)
holy f*** I like that! - I'm thinking of i7 2600k build, oc to 4,5 maybe
#59
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/17 04:22:07 (permalink)
updated with my settings to 5.1 ghz!
#60
