electronicsfreak
I have a motherboard that requires an 8 pin power connector for the cpu, but the EVGA power supply I have has only 4 pin connectors for cpu. Can I use two of those for the 8pin slot or should I just use one? Thanks
Re: 2 4pin cpu power in place of 8 pin?
2016/08/29 17:18:43
Welcome to the forums electronicsfreak If you have 2 of the 4-pin EPS cables use them both is OK if your PSU has the ports & cables Some / most MB will work with 1 of the 4-Pin EPS cables -check your manual, which side to use if only one 4-pin Remember the catch on cable MUST align with the bump on the MB socket -- or you will let the magic smoke out
post edited by Cool GTX - 2016/08/29 17:22:44
- Ribbons : 282
2016/08/29 17:19:50
Cool GTX Welcome
Funny What Model Number is your Power Supply? Some have cables that you put two 4-Pin to make your 8-Pin Power Cable, remember that the Cables Will be Marked to what they are for on all EVGA Power Supplies.
2016/08/29 17:20:28
electronicsfreak I have a motherboard that requires an 8 pin power connector for the cpu, but the EVGA power supply I have has only 4 pin connectors for cpu. Can I use two of those for the 8pin slot or should I just use one? Thanks
Yes, you can use both 4-pins.
2016/08/29 17:23:48
Cool GTX Welcome
speed in getting posting position, cause I type sloooow break the ice then fill in the blanks I'll let you catch the next one
post edited by Cool GTX - 2016/08/29 17:27:04
electronicsfreak
2016/08/29 17:24:50
Thought so but figured id double check as I had never ran into that situation before. Not my first build just never had that issue before lol. And thanks for the welcome.
2016/08/29 17:25:46
electronicsfreak Thought so but figured id double check as I had never ran into that situation before. Not my first build just never had that issue before lol. And thanks for the welcome.
Enjoy your new Toy
electronicsfreak
2016/08/29 17:26:21
The 4 pin wires I am referring to do say cpu on them. They are the ones for powering the cpu just wasn't sure on using two for 8 pin connector. Figured they were the same but wanted to make sure before creating a paperweight.
2016/08/29 17:28:22
electronicsfreak The 4 pin wires I am referring to do say cpu on them. They are the ones for powering the cpu just wasn't sure on using two for 8 pin connector. Figured they were the same but wanted to make sure before creating a paperweight.
EPS = CPU No worries; better to ask first. We all learn something new every day
post edited by Cool GTX - 2016/08/29 17:32:38
electronicsfreak
2016/08/29 17:37:14
Working in IT I can second that lol.
- Ribbons : 282
2016/08/29 18:13:39
Cool GTX Welcome
Yea! Yea! you only want the first post.
bob16314
- Ribbons : 761
2016/08/29 18:38:03
Always good to ask when unsure..But as stated above, you use both halves of a 4+4 pin CPU connector from the PSU in an 8-pin mobo socket. The reason for a 4+4 pin connector is for compatibility purposes..Some motherboards only have a 4-pin socket in which case you'd use just the 4-pin half..Some motherboards have an 8-pin socket in which case you'd use both halves..Some motherboards have an 8-pin and a 4-pin in which case you'd use the 4+4 pin in one and only the 4-pin part of another cable in the other..Still other have two 8-pin sockets..You get the idea..You can use only the 4-pin connector in an 8-pin socket, but overclocking/stability of the CPU would likely be very limited.
