Re: 1911 stock boost 6181 non-SC acx3 overclock help
2016/09/29 21:00:55
My card boosts exactly the same. I have found a +250 core and + 250 memory works incredibly well with the card if and when I overclock. Most times, I run stock speed & MSI Afterburner with a fan curve as follows: 40C-45 % fan; 50C-55% fan; 60C-70% fan; 70C-80% fan and then upward. My fans are absolutely quiet...no coil whine. I think that these cards are cherry! The card rarely goes over 71C, hits 73C when overclocked. Mostly, I use the power target of 110% so the card stays pretty steadily at 1911. It will jump as low as 1860 and back up to 1911 at stock speeds. I think you are pretty safe as long as you keep the card cool.
MSI MAG X670-E Tomahawk; Ryzen 7 7800X3D; Asus TUF RTX 4070 TI OC; Seasonic Vertex GX-1000 PSU; 32 GB Corsair Vengeance DDR5-6000 RGB; Corsair iCue Link H150i RGB 360MM AIO; 2-Western Digital Black 4 TB SN850X NVMe; Creative SoundBlaster Z; Lian Li Lancool III; EVGA Z15 Keyboard; Razer Viper 8K Mouse
Heatware: http://www.heatware.com/eval.php?id=72402 Affiliate code: 1L2RV0BNQ6 Associate Code: UD82LJP3Y1FIQPR
