Hot!1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 (non-FTW)
trilegdog
2016/07/17 14:49:36 (permalink)
Pictures from EVGA manual #E009-00-000164.  All copyrights are the property of the respective owner(s).
http://www.evga.com/Products/Product.aspx?pn=400-HY-5188-B1
Note: This kit is exclusive to NVIDIA Reference PCB/Air cooling 1080/1070 cards.
It is not designed for the FTW custom PCB. The FTW Hybrid Kit is pending release by EVGA.
Update:  Fan & Radiator Specs provided by EVGATech_AndrewA
Fan: standard 120mm fan.
  • 2.88watts peak (.24amp @ 12v)
  • ~2000RPM max
  • 69.5CFM
  • 2.76mm-H2O (static pressure)
  • 34.2db max
  • MTBF 50,000 hours
Radiator and tube specs:
  • Height: 152.5mm / 6in
  • Width: 121mm / 4.76in
  • Thickness: 27.5mm / 1.08in (this measurement does NOT include the fan)
  • Tube Length: 400mm / 15.75in
Edit by trilegdog 19 July : changed fan description  "2.76mm-H2O" to read "2.76mm-H2O (static pressure)"
Edit by Jedi:  Fixed link to product page.
post edited by trilegdog - 2016/07/19 14:23:15
Asus Formula VIII, i7-6700k, Tt Riing 360 AIO, 16GB Corsair Dom/Plat 3K,
EVGA GTX 1080 ACX 3.0 (6181), SS 850 Pro 512, 2xWD Blk 2TB, EVGA P2 1000w,
Dual Boot Win7Pro64 /Win10Pro, Tt Core X-9, SS2693HM 1900x1200, Fuzzy Dice
6181-KR Step-Up began 29 June, queue hit 29 Aug = 62 days
RMA 980Ti SC+ to EVGA 31 Aug. Recvd by EVGA 10:41 am 2 Sep
UPS track # issued 8 Sep - delivered 13 Sep 2:54 PM EST
HYBRID AIO 400-HY-5188-B1 Ordered 8 July - Recvd 15 July
EVGA 780i, E8400, 8GB OCZ (4x2), XPpro/Vista64
EVGA 8800 GTS G92 512 SLI (2), OCZ900MXS PS
lead, follow, or get out of the way
77 Replies Related Threads
    PasTecHi
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 05:12:57 (permalink)
    But that manual tho...seems pretty easy lel
    i7 2600k 4.5ghz | Corsair H100i Hydro | Asus P8Z68-Gen3 | Asus Strix 970 | Corsair Vengeance 4x4gb 1600mhz | Kingston 120GB SSD | Seagate 3TB |
    lordaeron1
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 07:10:17 (permalink)
    hmmm was to happy ... thought it's for FTW PCB also :(.
    hope the FTW hybrid kit comes out soon :S
    post edited by lordaeron1 - 2016/07/18 07:13:51
    I7-6700k (stock) | Msi M7 gaming | Kingston hyperx savage16Gb DDR4@ 2800Mhz | Evga Gtx 1080 FTW | Corsair H110i | Samsung 840  EVO 120GB SSD + Crucial Mx 200 250GB | Seasonic X-750w Gold | Cooler Master Haf X (Aka 932) | DELL U2713h | Xonar D1.
    EVGATech_RayH
    EVGA Tech Support
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 07:24:25 (permalink)
    Because of the larger PCB of the FTW model, this Hybrid kit will not fit. We will keep you posted about watercooling options for non-reference models in the future.
    lordaeron1
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 07:33:22 (permalink)
    EVGATech_RayH
    Yes i understand, i only bought FTW because every body said on forums that FTW hybrid kit is coming out soon. i don't mind waiting as long as it will arrive eventually :)
    lordaeron1
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 07:35:54 (permalink)
    EVGATech_RayH
    this what i meant... (This looks like a custom PCB cooler and different then the FE one. bigger shroud + bigger fan on the VRM)
    will wait for this kit as long as needed. :)
    post edited by lordaeron1 - 2016/07/18 07:45:05
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 21:37:29 (permalink)
    Updated op with fan & radiator info.
    Udo_G
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 22:38:05 (permalink)
    Thanks for this information. Do you know if this is the same fan which are used for the 980TI?
    Option
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/18 23:06:00 (permalink)
    Are these for sale yet or are they just sold out atm?
    Motherboard: Asus Maximus VIII Hero Alpha
    PSU: EVGA 1000 P2
    HDD(s): Samsung 850 EVO 1 TB
    RAM: Corsair Dominator Platinum 32 Gigs
    GPU: EVGA GTX 1080 Hybrid Cooler
    CPU: Intel i7-6700k @ 5.0 Ghz
    CPU Cooling: NZXT Kraken x61
    Case: Corsair 750D Airflow
    Os: Windows 10 Pro
    Steno75
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/19 08:05:09 (permalink)
    thanks!
    I want to put on my 1080 SC
    The shroud is included?
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/19 14:25:01 (permalink)
    Udo_G
    We need an EVGA Tech to answer your question.
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/19 14:26:42 (permalink)
    Option
     Sold out atm.  Bought mine on first day (I should have been that quick on my step-up).
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/19 14:28:06 (permalink)
    Steno75
    thanks!
    Yes Sir!
    Udo_G
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/19 14:42:32 (permalink)
    What are about the thermal pads - picture 6 - did you used the old/original one's or pads are included in the kit?
    Thx.
    jerzeeloon
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/19 15:16:19 (permalink)
    lordaeron1
    EVGATech_RayH
    Not to mention the most obvious thing. It has 2 8 pin connectors.
    corsair 350D
    Asus Maximus VI Gene
    4770k @ 4.2ghz
    8gb rip jaws X series 1600 888/24
    500gb crucial m4 ssd
    1tb wd caviar black
    Corsair AX760
    Gtx 980ti
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/19 19:47:30 (permalink)
    Udo_G
    Thx.
    I haven't installed the kit, awaiting step-up.  I intend to use the pads supplied.
    UnderwaterSurfer
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/21 16:49:24 (permalink)
    trilegdog
    Thank you for the photos, as I can't find the manual listed on the EVGA site yet. Is the backplate reinstalled? I don't see that listed in the manual.
    jerzeeloon
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/21 16:53:20 (permalink)
    Udo_G
    The 980ti hybrid kit used the reference fan. Looks like this one comes with a replacement fan. I'll know next week when my kit gets here
    corsair 350D
    4770k @ 4.2ghz
    1tb wd caviar black
    Corsair AX760
    Gtx 980ti
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/21 20:07:45 (permalink)
    UnderwaterSurfer
    trilegdog
    Good catch!  I didn't notice that. I hope that the plate can be reinstalled.
    It'd be great if an EVGA Tech would respond on this.
    jerzeeloon
    Udo_G
    Yes, it comes with fan, as seen in the pictures.
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/21 20:14:09 (permalink)
    I PM'd an EVGA Tech with the question on reinstalling the backplate.
    UnderwaterSurfer
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/21 20:24:50 (permalink)
    It is available on Amazon but not in stock, so I went ahead and ordered one for my EVGA GTX 1080 SC. I sure hope the backplate can be reinstalled, so thanks for sending the PM!
    Udo_G
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/21 21:40:17 (permalink)
    yes, the backplate can be reinstalled!
    trilegdog
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/22 07:02:06 (permalink)
    Thanks, Udo_G!
    EVGA Tech RayH responded.  From what he has seen, yes, reinstall.  Since that info was omitted from the install manual, he will be contacting the product guy/gal for a better detailed response.   I hope to get an additional picture loaded to cover the reinstall (likely just the reverse of step 1).
    Update:
    The detailed response provided is that the Hybrid kit does work with those compatible 10 Series cards that come with a pre-installed backplate.
    post edited by trilegdog - 2016/07/22 12:38:29
    #23
    UnderwaterSurfer
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/22 19:08:00 (permalink)
    EVGA now has this kit available for purchase!
    #24
    C_McButterpants
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/07/27 05:31:25 (permalink)
    Well, I have received my Hybrid kit and installed it with tremendous results:
    I went cheap on the stock MSI Aero 1070 blower at a mere £380; just wanting an interim card for next ~18 months.
    I can't speak to the effectiveness of a Founder's edition blower performance, but this MSI design is very poor - it idles quietly enough, but the fan profile needs ramping right up the wazoo under load; and it still hits high 80°'s causing throttling.
    *I need to point out that my case has very poor fan throughput (a low end Corsair 100r silent - 2×120mm intake/outtake fans on a triple speed header selector). This is why I've always stuck with blower cards; so the high GPU heat is better exhausted on long gaming sessions.
    There's no backplate to the MSI Aero, and aside from a slightly different design steel end plate, everything attaches as intended. I was initially unable to install the radiator in my case because of the previously mentioned fan speed switch mounted at the back above the fan mount. doh! There's room for the fan - but the rad is somewhat taller. Removed switch and no problem. I did attach the EVGA fan to this switch (rather than direct through card) so I can run at lower revs. This makes practically inaudible.
    Now, even with a fairly modest Overclock:
    I'm seeing mid 30°'s idle and hovering just over 60° under 100% load.
    So, is dropping an extra £120 on an (admittedly) low-end card some kind of tits-on-a-boar affair? Not at all!
    On first power up I did think I'd made a terrible mistake... I was getting a crazy vibration from the case - turned out to be the water pipes pressing on the side door! Zip-tying the pipes up to the card keeps them out of the way nicely.
    Now my cheap as chips reference PCB can run as intended; with a decent amount of OC headroom (for an 8-pin board).
    I can now explore No Man's Sky stress free @60hz & 3440×1440 and leave properly investing in the Pascal architecture until it's matured a little more...
    TL;DR
    EVGA Hybrib AIO cooler compatible with MSI Aero reference PCB card.
    Happy days. :D
    post edited by C_McButterpants - 2016/07/27 05:36:01
    #25
    protestjay
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/08/06 05:58:40 (permalink)
    Hi there, i just got one of these hybrid kits and was just wondering if it would be better applying my own thermal paste on to the dye rather than the pre applied stuff on the water block?
    #26
    UnderwaterSurfer
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/08/06 08:37:09 (permalink)
    I would think it better to use the pre-applied paste. The one I have had the paste applied evenly all over the copper protrusion, and it is my understanding that it needs to cover the entire chip. The temperature reduction is fantastic, and it is soooo nice to have the heat blown outside the case, as the internal case temperature is very low now! You can use SpeedFan to control the speed of the radiator fan if you plug it into a motherboard fan header, even though it only has two wires. You won't see the rpm because it is DC controlled, but you will see the percentage. At least that is how it is on my computer. I have the fan at 20% at idle, and at 40C it starts to ramp up to the highest speed at 50% when under full load. I can't hear a thing at idle.
    post edited by UnderwaterSurfer - 2016/08/06 08:46:55
    #27
    protestjay
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/08/07 03:43:07 (permalink)
    UnderwaterSurfer
    Cheers man, I think I'll stick with pre applied stuff, like you said it would provide full coverage on the dye, and it would save time taking thermal paste off just to re-apply some more. Had another question though, I opened the box just to check everything, did your unit have the thermal pads pre-applied onto the Baseplate? I thought there would be some pre cut and just had to stick on. But there wasn't any in my box, the only thing I noticed were black pads attached to the Baseplate that line up with the vrms and that. Just want to make sure this is OK before I go a head?
    #28
    UnderwaterSurfer
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/08/07 16:22:43 (permalink)
    After liquid cooling my EVGA GTX 1080 SC, I was able to get some very steady temps and overclocking. The attached image shows an MSI Afterburner graph after about 30 minutes of playing The Talos Principle, which I thought would communicate more than words.
    post edited by UnderwaterSurfer - 2016/08/24 08:09:59
    #29
    JD3206
    Re: 1080/1070 Reference Hybrid AIO Kit Install Manual for P/N: 400-HY-5188-B1 2016/08/09 10:27:35 (permalink)
    Anyone going through the install for the first time, just know that they skip quite a bit of detail in the included instructions.
    The biggest issue I had was getting the stock cooler off of my PNY 1080 FE and that was because they didn't mention two screws that were on the IO plate in the instructions.
    There are two and they need to be removed to remove the stock cooler and leave it in 1 piece (between steps 3 and 4):
    The other thing to mention is removing the screws (more like hex nuts?) that attach the cooler to board under the baseplate.  They also serve as the screw holes for the backplate and will need to be removed with a proper sized bit.  I was lucky enough to have a Kingston screw driver and the nuts were the same size as the bit holder for the screw driver bits.
    Other than that, the install wasn't bad to do at all.  I went from the edge of thermal throttling (80 to 84 degrees after playing for a while) with epic settings in Ark: Survival Evolved at 3440 x 1440 to a max of 43 degrees (with an added overclock!) at the same settings.
    post edited by JD3206 - 2016/08/09 10:40:56
    #30
