AHowes
Re: 1080 Classified problem limits going off at defaults.. on 3rd card.
2016/09/15 13:55:55
AHowes Meaning?? Voltage controller is unstable at that current voltage and is recommended to lower voltage for stability correct? Meaning it can't run whatecer speeds it is cause the voltage controller can't or is programed incorrectly or faulty right? Or something in the path is not good.
Also runing in overclocked mode in debug I don't get the temp or power limit at 1 like usual. Still wont run without lock ups at max voltage at 2000+. Not that I care. I'm only trying to get a stable clock like the first card that would never move cause of limits going off.
Voltage controller isn't unstable. I'm pretty sure the vbios on the card is set to limit voltage at 1.050v. So once you hit 1.050v it causes voltage limit 1.
Not on my first card. That classified 1080 never shows a 1 ever for any limit. Debug mode give me 0 control over the voltages.. gona try and see how low I can run the voltage to see if that matters any.
Intel i7 6700K Custom Water Cooled Asus Z170 Maximus VII Hero G.Skill 16GB 3600MHz DDR4 15,15,15 Samsung 950 Pro 512GB/Samsung 500GB Evo EVGA 1080 Classified SLI Water Cooled 27" Asus ROG SWIFT 1440 165Hz EVGA SuperNova G2 1000WATT P/S Thermaltake Core X9 Case w/ EK Cooling
2016/09/15 13:58:26
AHowes
What happens when you set your perfect 1080 to 1.093v? Does it show voltage limit 1?
2016/09/15 14:01:28
AHowes
Sajin How many times are you going to make a thread about this? http://forums.evga.com/He...-it-mean-m2549888.aspx http://forums.evga.com/St...assified-m2549362.aspx
No one seen it in the other one.. and this is also a whole different card.. card 3.
You should contain all of the same issues for your system to one thread. There is no need to create a new thread for each card of the same model number that you purchase. This is not really a "New Card" as it is still a 1080 Classified. If it were a 1080 FTW, FE, SC, or reference, then it would be a "New Card" and a new problem, but you are referring to the same model number and everything. Any further threads will all be combined so that the issue with one card can be tracked. Please keep your posts together.
If you would like to use an affiliate code to register a product, feel free use this one: >Click Here< This is not my affiliate code! This is a random users code. This code will change often, and you will never be told who it belongs to! If you would like the possibility of your code being listed above, it must be in your signature block. I will not take requests to use a specific code.
AHowes
2016/09/15 14:01:45
AHowes
Nope.. never.
AHowes
2016/09/15 14:03:30
Runing the card right now at the lowest it will manually allow me to and control the voltage and thats +50 at 1.05v and I get voltage limit 1.
If i do +75 I get all 1s all around at 1.050v.
2016/09/15 14:05:04
AHowes Nope.. never.
Hmm. Looks like the 3rd card is just junk then like the others you received or the software is giving incorrect readings.
AHowes
2016/09/15 14:05:35
Ah.. just got it to 1.044v and yup it's showing voltage limit 1.
AHowes
2016/09/15 14:10:50
Wait.. so far I'm able to test at lower voltage. Letso me get to 1.025v at +50 and yup still voltage 1. Tried lower at +50 and it will just go to 1.063v. Will try +25 and see if it let's me go lower voltage. Nope.. can't go lower.but atleast I know during the load screen of the physics test it runs at .875v and there's no voltage limit 1.. it's 0! Shocking.
post edited by AHowes - 2016/09/15 14:13:03
2016/09/15 14:12:58
Every card is going to react different. Plenty of FE cards can hit the same clocks as the classifieds, and plenty of classifieds are limited to much lower clocks. This is the silicon lottery, and it isn't always perfect. Classified cards are tested the exact same way reference cards are to verify they work at their specified clocks. Unfortunately, that does not guarantee that you are going to get perfect overclocks. For voltages, you should get a probe it cable, and test the true voltages with a multimeter rather than looking at the software. Software has never been quite right, and may never be able to properly read the voltage.
AHowes
2016/09/15 14:15:45
Scarlet-Tech
AHowes
Ok no problem.. just figured no one is seeing the thread in the software forum so I started one in the 1080 section since it is a 1080 issue. Should of deleted the old thread. No idea if one has the option so if you can just delete the thread in the software forum.
2016/09/15 14:18:37
AHowes
Scarlet-Tech
AHowes
I can combine the threads for you, but I am not sure if it is a card or a software issue. Once that part is figured out, we could combine them in the correct section. For now, it is fine, just so we don't put them in the wrong place.
AHowes
2016/09/15 14:29:03
Scarlet-Tech Every card is going to react different. Plenty of FE cards can hit the same clocks as the classifieds, and plenty of classifieds are limited to much lower clocks. This is the silicon lottery, and it isn't always perfect. Classified cards are tested the exact same way reference cards are to verify they work at their specified clocks. Unfortunately, that does not guarantee that you are going to get perfect overclocks. For voltages, you should get a probe it cable, and test the true voltages with a multimeter rather than looking at the software. Software has never been quite right, and may never be able to properly read the voltage.
Understand fully but the last 2 seem faulty to me.. if it was just a overclock limit as always like I've experienced with the last 10 1080 cards then yeah.. no issue run the 2 cards in sli at the lower clocks. I just don't want a custom card that allows for more power for more stable clocks being dynamically lowered by a issue with voltage limit going off all the time.. even at stock clocks. If that's going to happen I might as well buy the fe card. I've had another custom card the zotac and it was great. The amp edition. With just 1 in there it ran around 50-56c and was stable around 2088mhz. Was the first set of 1080s I bought. But once I added the 2nd the temps went out the window. Upper 60s to 71c. No thanks. Point is the clocks were stable! Custom card with dual 8 pins connections unlike the fe cards I bought next to deal with the heat. The pny 1080 fe cards were better clockers. Ran 2114mhz.. the best of the 2. Tempts in the 50-56c in sli. But super loud runing 85-100 fans to help keep the clocks up. Would jo jo all over the place. Bought water blocks for them so I didn't care about sound atm. Then once I read there policy changed this year stating no water cooling I had to return them ans went with good old evga that is fine with heatsink removal ( as always )and water cooling. Then I had the chance for the ftw hybrids.. much cheaper solution over custom water cooling so I had to snag it and please the wife.. no problem.. didn't open the water cooling andidn't returnespecially the cards.. someone got some good cards as they would play 2124+ mhz. Then the whole black screen issue with the ftw 1080 effected my hybrid ftw cards. :/ seriously?? So now I'm returning those to evga andon't i had to snag the classifieds.. Long story.. point. Custom pcb cards are the way to go but maybe I may have to return the single golden classified since the odds of me getting another normal card are 1 in 3. Prob be banned from the store after this return.
AHowes
2016/09/15 14:32:02
I can remove the power limit issue with getting a good custom 1080 card.. I can remove the temp limit with adding water.. I can't do anything with the voltage limit.
2016/09/15 15:02:50
AHowes
EVGA_JacobF Its normal, since frequency is tied to voltage what it means you need to your voltage, try setting voltage 100%. if still showing 1, increase frequency offset to force a higher voltage stepping.
Ok so if it's saying voltage limit 1 while runing the cards defaults "stock" and it's runing ingredients 1975mhz at 1.065v and that's not enough then I guess it's prob a bad card if it needs that much voltage.
And I can't wait to get home to test it with max voltage at that 1975.. cause if it don't go away wow.
I also believe I was able to lower the voltage at a certain mhz to get it voltage limit to 0.
It means that the voltage is limiting the frequency from boosting higher on that particular card. Its not bad, actually it is totally normal. All cards are different and have different voltage levels. You either need to force a higher voltage stepping via manual offset, or try setting voltage to 100%. But, as mentioned above, you may have hit the max voltage for your card already, and thus will not be able to go higher.
post edited by EVGA_JacobF - 2016/09/15 15:05:09
jfreeZr - [rebuilding] 4770k @ 5.2ghz || evga z87 classified || 2x evga gtx 980 acx2 || 16gb 2.6ghz ddr3 || 500gb 840 evo raid0 || evga supernova 1000 P2 hadronGTX - 4770k @ 4.4ghz || evga z9 stinger || evga gtx780 ti acx || 16GB 2.6ghz ddr3 || 480gb vertex3 raid0 || 500w gold
AHowes
2016/09/15 15:27:33
Ok thanks.
Just boxed up the 3rd classified to be returned/exchanged at mc depending on what I want to do.
Just slapped in the 1st card again an ran it at 2190mhz at 1.094v with 0 limits being hit. Close to 12k on the ram and it froze up after almost 20 mins so I lowered to +150 that's 2164 and it held it the whole time as usual no limits and got a score of 17688 in firestrike for single card. Valid score.. which it always said invalid score and generic vga card for 3dmark test results. No idea there.
Took pics if I feel like uploading them later.
AHowes
2016/09/15 15:51:39
Just ran a bench at 2190 with members at default and it finished it. Valid score only 17600 something. Tried +200 and it ran at 2215mhz! Though for only a few mins at 1.084v. So I tried lowering the voltage and it froze up quicker. Oh well. Anyways so far I've found high mhz on the ram don't help this card bench higher.. also high overclock on the core don't help much either in your score. Prob beat it with a fe card at 2114. Still testing.. Forgot to add. No limits tripped the whole time still. Prob should show a limit but it wont. I'll take it though haha.. keeps my clocks up from dropping.
post edited by AHowes - 2016/09/15 15:54:00
AHowes
2016/09/16 18:28:12
Tonight I've exchanged the bad classified for a 3rd.. will I go threw 3 bad in a row?? Stay tuned.m too many beers tonight to find out. Will test tomorrow!
AHowes
2016/09/17 09:25:42
4th classified is good! No limits at 1 so 0 down clocking of the core just like my first card. Default out of the box will run 2025mhz at 1.43v and climbs slowly to 1.05v i believe. Almost ran a bench at 2190mhz at 1.093v but locks up after 5 mins or so. 2164mhz is fine at 1.081v. All that is just icing on top of the cake.. just looking for a card that would match my first one with no limits going off (1) and dropping my clocks. Bench as high as possable but gaming I'll keep them at 2050-2100. So 2 out of 4 was good in the end. The new one was a scary 7 numbers higher then the last one! Was bummed when I seen that thinking there was a bad batch or something. So as the saying goes.. ya never know what your going to get. Ea chip is totally different and it's all silicon lottery. So the hunt is over finally.. hopefully they don't cook eachother with 1 slot in between but I'm sure it will happen if the first card will max out at 59c after an hour of witcher 3. Only flaw on the 2nd card I found so far is that the max the ram wants to do before artifacts is +500. At 600 I get slight screen flashing every now and then. The first card will run around 900+ almost 12k! No big deal. Water cooling may fix that but crap would cost me another $260 for ek blocks and $34 for a bridge and another $80 for a 120.3 rad. Wife won't let me. Could go custom old school swiftech universal vga water blocks and just keep the black aluminum plate on there to cool the mem and vreg and point a powerful fan at the end of the cards but I feel it's risky.. though the overkill 14.3 phase controller does as I've read run much cooler but cool enough?
post edited by AHowes - 2016/09/17 09:32:44
CoercionShaman
2016/09/17 09:55:25
Good. I don't care what anyone says, the other cards should not have been hitting power, voltage and temp limits at the same time and especially not when all were within limits to begin with.
What use is knowledge if there is no understanding?~Stobaeus Intel i5 4670K @ 4.2GHz, Corsiar H100i v2 AIO, 32GB G-Skill Trident X @ 2133 MHz, MSI 1080 Gaming X w/ 2139 MHz boost, ASUS Maximus VI Hero, Samsung 840 EVO 240GB, WD 750GB, CM V1000, Dell U3415W 21:9 @ 75Hz, Windows 10 Pro AE, CM Storm Trooper
AHowes
2016/09/17 10:45:51
True.. very true. Even down clocking the core -200mhz in debug mode runing 1600+ mhz the voltage 1 would be there waiting for me at anything over .875v.
With the osd up I could watch it and during bench load screens it would be 0 for the limit at .875v but as soon as it starting runing voltage limit 1!!
AHowes
2016/09/17 10:49:31
Oh I will also add that I tested the first card just to make sure there wasn't a problem with it since the limits nevery turned to 2 from 0. So I put the fan profile back to defaults.
When I ran it, once it climbed up to a good temp over 60 there the ones came flying up! Hehe. Fan was barely turning and at like 20% was freaking out that it didn't even turn on till upper 50s.
AHowes
2016/09/17 12:57:38
No good with these 2 in sli. The first card is cooking at 65c.
2016/09/17 13:46:26
Glad to hear your problem is resolved. 65c is far from cooking.
AHowes
2016/09/17 14:36:07
Sajin Glad to hear your problem is resolved. 65c is far from cooking.
True.. but that's just a 10 mins loop of firestrike graphics test 2 loop. Prob see 70+ in a long normal gaming session. I slapped a fan on top of the 2 cards in the middle. My mb is horizontal in my thermaltake core x9. So I have it sacking the heat off the cards blowing the heat up to the exhaust fans. With that I get around 60c. Don't look or sound good though hah. Going to clock them at 2100 and see how low I can go on the voltage to see how much it lowers the temps if any.
AHowes
2016/09/17 20:37:43
2114mhz is the best it can do it seems cause of the heat. I even have a fan behind the end of the case to blow cool air threw the card slots that helps quite a bit but obviously don't look too great but does drop the temps like 5c to the first card with the card fans blowing 100%. Max temp no matter the clock is around 65-67c.
Evga's new pc case with the left side case fans would prob work perfectly to do this job with them blowing cool air in for the 1080s fans.
I'm prob gona go that route and order one. It's like that or a lot more to water cool the cards.
krex_core
2016/11/12 19:50:11
I'm having the same issue as the OP. Should i just take this card back to Microcenter (I got it as an open box deal) and get another one or is it not the small difference in OC really worth going through the exchange process.
krex_core
2016/11/12 20:02:03
It hits voltage limit =1 with no oc what so ever
krex_core
2016/11/12 20:15:52
I just notice whenever the voltage goes above 1.050 it the power limit shows 1 immediately. I'm guessing the voltage goes up with no OC because of that boost thingy. The card will be returned in the am.
AHowes
2016/11/13 05:59:56
