1070 FTW LED PROBLEM
tonytony11
2016/11/19 08:20:38 (permalink)
Hello! I've got a brand new GTX 1070 FTW and downloaded EVGA Precision XOC. The problem is that I can't change the led color/effect. Any ideas?
11 Replies Related Threads
    billdo
    Re: 1070 FTW LED PROBLEM 2016/11/19 19:33:31 (permalink)
    I have the same issue. 1070ftw hybrid on windows 10 64bit
    Inferion
    Re: 1070 FTW LED PROBLEM 2016/11/19 19:50:47 (permalink)
    tonytony11
    http://international.download.nvidia.com/GFE/LEDViz/1.0.0.0/LEDVisualizer_v1.0.0.0.exe
    Try installing this 1st. Cause on the new nvidia drivers they didn't pack the LED Visualizer with in it.
    Hope this helps.
    Corsair 760T Graphite
    EVGA Z170 4-Way Sli Classified
    Intel i7 6700k w/ Corsair H110i GTX AIO Cooling
    Corsair Vegeance LPX 2x8GB DDR4 2400 Mhz (Soon to be upgrading to Corsair Dominator Platinum 2x16GB DDR4 3000Mhz)
    EVGA Geforce GTX 980ti Classified x2 (Waiting for my 1080 Classified)
    Corsair AX1200i
    Samsung 850 Evo 250GB SSD
    Western Digital Black 2TB
    Windows 8.1 64bit Pro
    tonytony11
    Re: 1070 FTW LED PROBLEM 2016/11/20 03:52:49 (permalink)
    Inferion
    tonytony11
    Hope this helps.
    It works but I can't change the led color
    emsir
    Re: 1070 FTW LED PROBLEM 2016/11/20 04:04:42 (permalink)
    tonytony11
    Inferion
    tonytony11
    Hope this helps.
    Open Precision X > down on the right side next to profiles you click the settings. Now click LED and change to what you like.
    tonytony11
    Re: 1070 FTW LED PROBLEM 2016/11/20 04:19:01 (permalink)
    emsir
    tonytony11
    Inferion
    tonytony11
    Hope this helps.
    Still can't press LED in the program
    cNone
    Re: 1070 FTW LED PROBLEM 2016/11/20 06:17:07 (permalink)
    I have the same issue:
    GTX 1070 FTW LED issue and I have opened a support ticket on this matter...
    edit: can't add links as I am new to this forum.
    post edited by cNone - 2016/11/20 06:57:33
    tonytony11
    Re: 1070 FTW LED PROBLEM 2016/11/20 06:18:43 (permalink)
    cNone
    How to open support ticket? I would like to do this too
    asus939
    Re: 1070 FTW LED PROBLEM 2016/11/20 06:23:33 (permalink)
    Try the old driver I run 373.06 an LEDs work fine
    billdo
    Re: 1070 FTW LED PROBLEM 2016/11/20 09:13:33 (permalink)
    Nope, still a no go.
    cNone
    Re: 1070 FTW LED PROBLEM 2016/11/20 11:54:42 (permalink)
    tonytony11
    cNone
    You have to register your product first, and then you can open a ticket ;)
    tonytony11
    Re: 1070 FTW LED PROBLEM 2016/11/20 11:58:05 (permalink)
    cNone
    tonytony11
    cNone
    Tnx I have opend a ticket, I hope they will solve the problem
