Answered1000G2 and four 6+2pin + 6pin cables ?
mtbdude
2015/07/29 17:37:09 (permalink)
As you can see below, I have 4 GPUs that have each have an 8pin connector and a 6pin. Can this PSU handle four 6+2pin + 6pin cables? The specs that came with it (see attached)  show that VGA ports 5 and 6 can use such a cable but ports 1-4 show just a 6+2pin cable.
Hope this makes sense. Thanks for any advice.
Intel Core i7-4790K
ASUS Z97-WS Motherboard
4 x Gigabyte GeForce GTX 970 G1 Gaming Graphics Card
Corsair Dominator Platinum 32GB (4 x 8GB) DDR3 2133 MHz (PC3 17000), 1.65V Desktop Memory
EVGA SuperNOVA 1000G2 1000W ATX12V/EPS12V 80Plus Gold Power Supply
Re: 1000G2 and four 6+2pin + 6pin cables ? 2015/07/29 17:58:44 (permalink)
The cables can be plugged into any of the vga ports on the psu. I wouldn't use any cables that aren't designed for the psu. Where are you getting the two extra 6+2 + 6 cables from?
Vlada011
  • Ribbons : 11
Re: 1000G2 and four 6+2pin + 6pin cables ? 2015/07/29 17:59:29 (permalink)
Use these cables for 8 pin, every cable in one graphic card.
Than use these two cables...
...and one connect in 1st graphic 6pin, other end of cable same 6pin connect in 2nd graphic card.
and other cable connect in 3rd graphic card and other part connect in 4th graphic card.
On cables from second pictures you will see one part 6+2pin+6pin... 2 pin you move on side and connect only 6 pin in one card and 6 pin in card below.
That's  GTX970 and some exibition with new cables don't need, power consumption is very low, PSU is single rail and you can connect.
With stronger cards better is if you use 1000 W for SLI and every connector own cable.
http://www.evga.com
http://www.intel.com
http://www.nvidia.com
https://watercool.de
http://www.lian-li.com
mtbdude
Re: 1000G2 and four 6+2pin + 6pin cables ? 2015/07/29 20:15:34 (permalink)
From EVGA. I bought into an Individually Sleeved set. Now I have 2 red factory cables and 2 white sleeved. I'm going to work on the aesthetics later  :)
Pgcmoore
  • Ribbons : 14
Re: 1000G2 and four 6+2pin + 6pin cables ? 2015/07/29 21:21:32 (permalink) ☼ Best Answerby mtbdude 2015/07/30 08:09:38
It will work, but you may be using more than 85% efficiency on the PS.
More info here..
http://www.anandtech.com/show/2624/3
   "This program has performed an illegal operation and will be shut down"
                        My Affiliate Code is  05G-UGD-GZVU
mtbdude
Re: 1000G2 and four 6+2pin + 6pin cables ? 2015/07/30 08:09:26 (permalink)
Yeah, I think I may bump up to the 1200 or 1300 PS.
Thanks for the info.
